Question about Nikon Coolpix S30 Digital Camera White
Memory Card/Battery Compartment won't open
I used my camera in the ocean and did not try to take the memory card out of the camera until I got home from my vacation. Now the compartment that it is in will not open. Is this because of the salt water? Is there something I can do to get it open? I have read in other forums that people are having trouble with the compartment door not being able to stay shut so I don't want to continue to force it to open
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • Nikon Expert
  • 132 Answers
In General... You need to slide something first and then open the door. Please looks at your manual.
Posted on Sep 17, 2017
bunnykinjoe
  • 3 Answers
SOURCE: Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Posted on Aug 15, 2007
xMadx
  • 64 Answers
SOURCE: Memory card cannot be read
Well this could come from one of 2 problems that spring to mind...
1. You do not have the correct software installed on your PC, as thus presents a problem in reading said memory card, especially if you are using non-specific or generic software.
Ensure the software you are using is for the Nikon Coolpix S200.
2. The memory card may also be faulty, if you feel this may be the case, i suggest having a dealer or repairer take a look at the card.
Tip: Some photo labs have self service units for most types of digital cameras. Drop in and try establishing if the memory card can be read.
Posted on Jan 19, 2008
Teckies
  • 226 Answers
SOURCE: No memory card will work in my Coolpix camera
Nikon has tested the following cards and approved their use in the Coolpix 3200:
SD memory cards:
SanDisk 16/32/64/128/256MB
Panasonic 16/32/64/128/256/512
Toshiba 16/32/64/128/256MB
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Multi Media cards (MMC) are not recommended and should not be used.
Posted on Jan 23, 2008
ARTGIRTNY575
  • 96 Answers
SOURCE: My Nikon Coolpix 2100 Lexar starter memory card has become unreadable
It sounds like your Dazzle is not compatible with the sandisk. Maybe the Sandisk CF UltraII card have a new update software in it.
Artgirlny
Posted on Jul 08, 2008
SOURCE: Camera says memory card cannot
there is problem in memory card slot wiring,just insert the card while camera is on it will definatly solve your problem.
Posted on Nov 02, 2008
How do you install memory card & adaptor in olympus fe-20
The memory card will be in the same compartment as the battery. Open the up and slide it in until the catch lever locks it in.
Jul 26, 2014 | Olympus FE-20 Digital Camera
Battery compartment stuck
I think you should take it to the camera expert who will open it safely and fix your problem.
Jul 15, 2013 | Nikon Coolpix S30 Digital Camera White
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Camera says "No Memory Card"
Good day!!!
try to test other memory card..
if the problem persist you need to clean the memory card port by using instant contact cleaner and wait until it completely dry before you open it and make sure the battery is remove to the camera while do this procedure..
thanks for using fixya..
have a nice day!!!
Jun 30, 2011 | Cameras
How do I remove the memory card from my Lumix 8x Vancouver 2010 camera?
The card is in the battery compartment. On the bottom of the camera, slide the release lever in the direction of the arrow and open the battery/card door. To remove the card, push the card until it clicks, then pull the card out upright. Hope this helps.
deanivie
Mar 13, 2011 | Panasonic Lumix DMC-FS3 Digital Camera
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
How do I take out the memory card?
Hello there,
You should push the card down to eject itself up. Then just pull it out from the compartment.
Hope this helps. Please let me know. THank you for using FixYa.
Jan 23, 2011 | Casio EXILIM EXS7 Digital Camera
Mine too mine is a kodak easyshare C330 and when i plug it it it won;t charge or turn on! please help im begging im taking it to camp in 2 weeks do i need a pro- help or is there an easy way (it uses AA...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 22, 2011 | Kodak Easyshare M753 Digital Camera
Shutter stays open. says turn off and on when
cameras : My Camera Freezes When I Turn It On Or Take A Picture
P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} If you camera freezes when you power it on or when you try to take a picture, you may have a defective memory card. To test your camera and the memory card, follow these steps:
  1. Power off your camera.
  2. Remove the battery from your camera. If you have a memory card inside the camera, remove that as well.
  3. Clean out any dust or debris inside the battery compartment, and then re-insert the battery into your camera.
  4. Power your camera on without the memory card installed.
  5. Take a picture.
    • If your camera takes a picture, re-install the memory card, and then go to Step 6.
    • If it does not take a picture, your camera requires service. To set up service, click the Create Online Service Request button below.
  1. Format the memory card in the camera, and then take another picture.
  2. Important: Formatting erases all pictures and other data from the card. If you have pictures on the memory card you want to keep, download those pictures to your computer before you format the memory card.
    • If your camera does not take a picture with the formatted memory card installed, replace the memory card.
    • If the issue still persists after you’ve installed a new memory card, your camera requires service. To set up service, click the Create Online Service Request button below
Jul 25, 2010 | Samsung L77 Digital Camera
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
Nikon Coolpix S30 Digital Camera White Logo
67 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
