Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer makes a wild noise while spinning
This washer while spinning makes a loud noise. I noticed that the drum is not spinning dead on center, but rather rotates and the top part of the drum hits the metal provoking the noise. any ideas will be appreciate it. needga
  • needga Aug 31, 2007
    thank you for your time. I found the problem to be an extremely heavy load of good quality towels. They absorbed so much water and they were distributed un-evenly in the machine. Once I removed half the load, the machine works fine. It is working great now.
  • 19 Answers
Be aware your washers bearings sound like they are collapsing (hence noise and rotation). Can be an expensive job to replace by a mechanic, get an estimate to see if its worth getting fixed.If you have to use washer in the meantime, watch it like a hawk and dont just set it away and go out,very probable flood damage etc ..Sorry theres no quick fix with this problem but i hope this is helpful.
Posted on Aug 28, 2007
Drum suspension failure
The suspension spring of the drum has come off and this means that the drum is hanging off the center.
The drum is hung with spring and shock absorbers and if one side has come off it will be off balanced. The springs are hung from the corners of the BODY FRAME. Check this out, replace spring if the end had broken or also you can use a good plier to extend the spring head to be clipped.( if broken)
Dec 30, 2012 | Asko WL6532XXL Washer
Washing machine travels during the spin cycle
Hi - Try to rotate the drum when it is not in use, manually and see if you notice the sound as well. If you do the drum is not balanced and you would need a professional technician to diagnose the bearing and pulley system behind the drum for repairs.
Oct 27, 2012 | Frigidaire ATF6000ES Front Load Washer
Wtw5640xwi
see this causes and fix it. God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Clutch If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission
Oct 16, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a ge frontload washer and it recently started making a really loud noise when in spin mode. It sometimes bangs the side also. What's going on?
It could be a few things that could be wrong with it. With the washer empty does the wash drum sit centered within the door? Also the drum should be level and not sag down or up. If it does, then it could mean the the springs or shocks are broken. You can check shocks by removing the two screws on the front bottom access panel. There are two shocks, and are mounted on the bottom of the the drum.
If the drum sits level and centered in the door, turn the drum by hand and feel how it spins. It should spin true and quietly without any kind of thumping or scaping noise. If it makes a thumping or scraping noise, or it wobbles as it spins this could mean the the spider arms that support the wash drum are broken. If it does not make any abrupt noise when you spin it by hand but when the machine is in a spin cycle, it spins with a loud roar like a jet plane is landing in your laundry room, then the bearings are gone.
It can be very expensive to have these machines servied since the machines needs to be taken apart to get the drum/bearing assembly. If you are handy, you can replace the bearing and seal for less than $100 in parts, but, if the spider assembly is broken, the parts alone can cost as much as a new washer.
Apr 19, 2011 | GE WSXH208A Front Load Washer
My Kenmore Elite 3T washer has a loud whistling noise in the spin cycle. ??? Thanks!
Hi.
When that happens it is often because the drum bearing is starting to go. The first symptom is a loud high pitched noise during the spin part of the cycle. As problem gets worsening you will notice that the drum will be a bit wobbly if you spin it by hand.
Here parts and diagrams.
Regards.
Ginko.
Mar 10, 2011 | Kenmore HE3T Washer
My admiral washer ATW4475TQ0 makes a thumping noise at end of spin cycle and when lid is opened during spin. What could be wrong?
there are stabilizers on the drum if they have fell off or broken away the drum will swing wildly around on spin this will cause the drum to "hit" the inside of the washer,,,check the drum stabilizers are in good order
Aug 08, 2010 | Maytag Washing Machines
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Making a loud noise when on the spin cycle and not balanced
It could be a drum spring has broken or stretched too far, there is too much of a heavy load in the drum, or the bearing needs replacing.
Sep 11, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
220 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
