Question about Hozelock Cyprio Prima Xl 3400 Gph Pump
Replace hozelock prima xl 6000 pump - Hozelock Cyprio Prima Xl 3400 Gph Pump
Can you help me my garden pond keeps going murky i have 2 ultra violet lights in it i keep changing my water but does not get any bettter
26 fish is a lot unless it is a big pond. Cold water fish create a lot of detritus. Do you have a fountain to aerate the water? Margin plants will also help. You could also add a pump and filter. I found this unit for you.
http://www.hozelock.com/aquatics/filters-and-uvcs/easyclearfilter/easyclear-6000--1-240.html
Aug 23, 2015 | Garden
Where can I get a conversion software
I also have an XL-6000, and I have the PSW 1.0 software. There is a patch for the 1.0 and 1.1 software for Win 7, as well as instructions. I would recommend that you join a Yahoo group called TeamSewAmused. It's dedicated to the XL-1000, XL-5000 and XL-6000, as well as the PSW 1.0 and 2.0 software, and they have LOADS of instructions in their Files section. Your software WILL run in Windows 7 and Windows 8 and 8.1.
Oct 11, 2014 | Singer Quantum XL-6000 Computerized Sewing...
How can i fix a leak inside my hozelock auto reel
adcccc13-7653-4a1a-83fe-508669c9a82e.jpg3187e97b-8b8e-4ed3-a2a0-0cad5211d982.jpg94e5325e-ed0d-4067-ba2e-15c982ded717.jpg350c6d53-8941-4e5f-937d-9425b18f4c89.jpgb9a1ffa9-99fa-4f32-9be1-717dd9251c09.jpg961cd592-0df3-420b-b7df-1b0ff17df252.jpg79809fc2-3e1f-4099-a3c7-00615892aa40.jpgd539f880-39af-40f4-850d-ad70e7f5948f.jpg7ce9923d-118a-4f30-9f13-20afc72d3ee9.jpg6d0fe000-779a-4d41-b1cc-81a243223d36.jpg2123ca49-4e92-4d43-a6cb-d6dab2644c3d.jpg9bcb85f0-f600-42e0-a249-d54524038b72.jpgea7bcfd2-840a-4496-a010-53e4229d922a.jpg6b9a17a9-5cc9-4ef8-8b28-3ddaee1a2172.jpgf3a3c78c-6856-4c78-bf68-90484825b7a0.jpgJust replace the O-rings inside. See pictures how to take it apart.
Jun 01, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Need instructions on how to install hozelock cyprio filter & pump
need instructions on how to set up filter, hazelock cyprio please
May 21, 2011 | Hozelock Cyprio Prima Xl 3400 Gph Pump
I have a brand new hozelock easyclear 6000 pond pump. When I plugged it in.....nothing!. Outdoor electrical socket working ok. The pond is newly built so their are no leaves or sludge in the pond, in-fact...
Sorry to hear of your setback but hopefully we can get you back to worrying about your pond occupants rather than the equipment. First remove the filter cover and filter and give the impeller a gentle turn to feel if the bearing or motor is jammed. If it turns freely try powering the unit to check if the impeller turns, sometimes the impeller needs a little bump to get it moving at first. If nothing still happens return the pump for a replacement.
Mar 28, 2011 | Imperial Garden Products OSI Submersible...
I have a hozelock bioforce filter that i have
Sounds like the the bypass valve may have been disturbed and so water is coming out of the air bleed hole.
I suggest you turn off the pump, remove the bypass valve cover (clear part that quater turns off bayonet style), extract the red valve (careful not to lose spring), rub some pertoleum jelly (vaseline) around the seal of the red valve, replace spring, red valve, press the red valve a few times to ensure it returns, replace clear cover and turn pump back on.
This should ensure the valve is working.
May 23, 2010 | Hozelock Garden
Describe your how to oil singer xl 6000 Problem
Singer doesn't recommend self-oiling on this machine, that is why there are no instructions in the manual. You should take your machine to a trusted repair facility for oiling.
Dec 27, 2009 | Singer Quantum XL-6000 Computerized Sewing...
How do i take apart and fix my Hozelock Titan 1450 pump''
http://www.hozelock.com/uploads/pdf/spares%20manuals/2008%20AQUATICS.pdf
Apr 04, 2009 | Garden
Hozelock Cyprio Prima Xl 3400 Gph Pump Logo
54 people viewed this question
Top Hozelock Garden Experts
richie46
Bill Boyd
Vernon Taylor
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
