Problem with graphics card
Every now and then my computer freezes and I get an error about the graphics card
  • Cunning Linguist Jul 15, 2013
    What error message do you get?
    Brigadier General:
  • 3,400 Answers
Proberly all computers have the same message it depends on the driver (GRAFIC DRIVER STOP RESPONDING AND HAVE BEEN RESTORED) it is nothing to do.if you don't wan't to do a rollback.
Posted on Jul 15, 2013
Slow running game
It might be due to fault in computer graphics world that's not recommended for the game that makes the script working imperfectly. Glitches in a platform game may show error of invisible wall collision errors, sprite errors, freezes, image problems, and others.
So all you have to check your hardware and re-install graphics drivers can fix your problem. Also have a look to game requirements for running on PC platform and can fix your error.
If you are unable to fix this problem even if Graphic drivers are up-to-date. Then best and easy solution is to use system utility program PC Fresher
Sep 06, 2013 | Ubi Soft Prince of Persia: The Forgotten...
When i start my fifa 11 then it can't start its writting E0001,what shoul i do?
Lol just change your resolution and then change back....worked for me
Dec 10, 2010 | Computers & Internet
G5 Graphics Card Freezes or begins to show lines on display
Since you are able to see your mouse pointer move, the display is refreshing so the problem is with something other than the graphics card. Generally software / OS related.
So assuming you aren't experiencing a hardware failure try the following...
Boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot from the CD
If so run disk utility from the CD and repair the disk as well as permissions. If there are any errors repair again.
If this is successful your computer "should" be repaired. If it is still freezing, use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Cheers
Mar 02, 2009 | Apple iMac G5 Desktop
Computer freezes with black screen
check that all cables are securley fitted to your drives . try unistalling the graphics card , boot up the computer , if it boots up then you will need to install the drivers that came with the graphics card first
Jan 25, 2009 | MSI : 661FM-L P4 SIS661FX FSB800...
Game crashes
Has it just started doing it?
if so have you changed/installed anything?
Check the actual card to make sure the fan is still spinning on it
other than that check the caps on the card make sure they are not blown...
Let me know...
Matt
Jan 22, 2009 | ATI RADEON 9700, (128 MB) Graphic Card
VPU Graphic Accel. Error
if you can reach the setup of the game before the screen freezes, go to the games setup and configure the video or graphic setup to match your graphic card or if this does not work do this 2nd solution. check for an updated driver of your graphic card and make sure you have a directX 9.0c
Dec 20, 2008 | Computers & Internet
Windows Xp SP2 prpgress bar freezing
You must uninstall the drivers of your old card before installing the new card and drivers.
Also make sure the BIOS is set to automatically check what you are using, onboard video (if available) or graphics card.
Jul 24, 2008 | ATI RADEON 9250, (256 MB) PCI Graphic...
Computer freezes up
Ok so i'm going to probably get flamed for my suggestion here, but bear with me.
  1. Take out the new fx5200 video graphics card and reboot the computer. If the freezing stops, then the card itself is most likely faulty or incompatable with your particular PC, or may also simply have a fault in it.
  2. Computers that ran fine before a new piece of hardware/software was installed, can nearly always be blamed on the new device or program. Simple solution is to remove the last thing you added and work backwards from there.
  3. If the freezing still happens, i suggest that you could also have a faulty ram stick, and you can test these with a RAM testing program, but they don't always show errors the first time you run them, so it may take several test runs to show the problem.
  4. An easy solution ( if you think you may have a faulty ram stick or Dimm slot, you can try removing the stick/s from the Dimm slots 1 by 1 until the problem stops, this can mean you have either a bad slot or bad ram stick, either way you should be able to work out what the problem is fairly easily.
  5. The only other problem i know of that causes long freezes or pauses, is not enough ram - or what is called missmatched ram.
Feb 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
My computer freezes
You could try with reinstalling the drivers for the graphic card. Another problem could be that you don't have all the codecs needed (But it doesn't usually freeze windows, only the software). Try downloading a codec pack from the following site: http://free-codecs.com/Codec_Packs.htm
Jan 27, 2007 | ASUS N6200/TD GeForce 6200 AGP 256MB DDR...
Computers & Internet Logo
453 people viewed this question
David Payne
David Payne
