Question about DeLonghi BAR 140 Espresso Machine
Failing delonghi espresso machine ed140
Until two months ago we were extremely happy with our machine--low price, great little espresso, etc. however, despite regular cleanings (or maybe because of, who knows?), it recently gave up the crema--the coffee comes out, but very slowly and with little or no crema. admittedly, we probably overuse the machine--10-15 per day, but we're careful and didn't expect it to give up the ghost after only a year and a half! do the pumps on these low-priced machines usually give out that quickly? is there anything we can try?
  • Anonymous Jan 27, 2008
    Yeah, I have the same problem. I've taken it apart, cleaned it thoroughly, and run vinegar through it, without solving the low-pressure problem. I'm convinced the pump is shot. Can anyone suggest where to find a new pump?
    Yeah, I have the same problem with low pressure after about 1 year. I've taken it apart, cleaned it thoroughly and run vinegar through it, without solving the low-pressure problem. I'm convinced the pump is shot. Can anyone suggest where to find a new pump for a DeLonghi BAR 140?.
Check the filter holes. They might need to be cleaned with a needle.
Posted on Aug 31, 2007
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
Coffee runs too slowly and tastes awful - DeLonghi ECO310BK 15-Bar-Pump Espresso Machine
Hi
Yes it may need descaling - deposits like calcium etc from 'clean' town water will build up in the machines boilers and tubes over time - that's why we descale them regularly - even if they don't get a lot of use.
Suggest you get some proper descaling liquid, not vinegar or CLR, read the manual on how to do it (download it off the net if you don't have it). ( it takes a little while as the descaler has to eat away those deposits and the machine will pump a little water out, then wait for a while, pump a little more etc until its finished the process)
Make sure your filter in the coffee dispenser handle is clean as coffee itself will build up and block those tiny holes if the machine is not porperly cleaned each day when used.
Cheers
Mike
Dec 09, 2017 | DeLonghi Coffee Makers & Espresso Machines
Won't heat up
nosolo, i descaled my machine with water and vinegar do you think i damaged my machine? I can't even get it to pump water, when i turn my machine on, it's silent, how do i descaled it again?
May 22, 2013 | DeLonghi EC702
We havn't had our Delonghi BCO-120T but for 3 months & the coffee side stopped working all together. My husband is a great handyman & after taking that side apart. the tubing & tank looks...
In uk delonghi spares by agents of kenwood.co.uk. there is a directory of local agents. before ordering element check thermal fuse attached to the element it may be open circuit.
Jul 29, 2010 | DeLonghi BCO120T Programmable Espresso /...
Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
May 24, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Espresso brews very slowly
when was the last time it was cleaned. it sounds like scale and deposits have built up inside the machine.
Oct 26, 2009 | DeLonghi EC460 Espresso Machine
DeLonghi Magnification 3300 leaking
The screws are hidden behind the water tank and inside the door area.
Sep 05, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi EC701
Could be scale build up. Do you have well water? You should run a descaler or white vinegar through the unit often to keep the boiler outlets clean.
Unless you are saying that the pump just doesn't run, ie, no noise, vibration, etc. Then, thanks for the warning that their pumps are bad.
Dec 30, 2007 | DeLonghi EC701 Espresso Machine
DeLonghi BAR 140 Espresso Machine Logo
463 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
