Question about Miele Washing Machines
Miele w2839 washing machine technical fault f63
SOURCE: miele w3033 tech fault f63. what to do?
i have washing machine miele gala grande w 3000.and i have a tech fa ult f63.what is this?
Posted on Jul 03, 2010
SOURCE: hi,i have a washing machine miele w 3000 tech
Mine is W3844. Miele's technician said the Wather Path Control Unit (part # 6271992) need to be changed.
Total Cost: (HKD)
450 for todays check cost
1100 for the part
250 for the labour to change the part.
Posted on Jul 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: side door is hinged
There are kits for doing just that.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
  • 500 Answers
SOURCE: hello, i'm facing the following
Hi vianney_dupa,
Your water path control unit is not registered by the PC Board. This is the Pressure switch / Water Level Switch. I'd kindly suggest you get a qualified technician to come and check your machine. If not well diagnosed it may lead to further damaging the machine.
Sorry, no quick fix here - This is were Miele machines get complicated O.o..
No need to vote my answer, I'll understand.
Posted on May 12, 2011
  • 251 Answers
SOURCE: My Miele 1374 washing machine
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
Posted on Jun 14, 2011
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
Dec 10, 2016 | Miele Washing Machines
Fault F63
Roger
Depending on the model number - (guessing its a W48XX series) F63 is a water path fault - This is the control unit that directs the water flow to the proper path (pre-wash, detergent, fabric softener ect..... ) Sometimes and audible clicking can be heard when this unit fails as it trying to switch to the proper path as per the program being ran.
Dec 08, 2013 | Miele Washing Machines
Miele fault F63
F63 on certain washers is an indication of too much soap is being used. If you live in an area where the water is hard and your not using too much soap you have a clog in one of the hoses used for air. Try to do a hot cycle with white vinegar. On other models the F63 is indicating that the water intake valve didn't find it's position. If this is the case just run an additional cycle.
Jan 21, 2012 | Miele Washing Machines
My Miele 1374 washing machine just had a fehler f63 error. What does this mean and is it fixable?
Jun 05, 2011 | Miele W 4800 Front Load Washer
Hello, i'm facing the following issue technical default F63 on the W5794 washing machine thanks in advance for your precious help regards
Hi vianney_dupa,
May 12, 2011 | Miele Touchtronic W1213 Front Load Washer
Hi,i have a washing machine miele w 3000 tech fault f63.what i can do?
Total Cost: (HKD)
1100 for the part
Jul 03, 2010 | Miele Washing Machines
Miele w3033 tech fault f63. what to do?
Jul 04, 2009 | Washing Machines
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
