Question about ASUS GeForce GTX 770 GTX770-DC2OC-2GD5 Video Card
Connect instructions I have two connectors do I use both?
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
Problem to connect walkera cb100 esc controller connector
there are only 3 combinations on connecting esc to brushless motor. if nothing indicated on wires you can try each combinations of 3 wire by keeping 1 wire choosen and trying rest 2 wires. dont worry you wont burn anything. only motor runs on other way.or it wont move but makes noise.
Nov 18, 2011 | Toys
Have only two wires how do i do?
You are apparently replacing a single switch, which only requires two wires (plus ground). The following directions are straight from the Intermatic directions that you can find at the link further below:
If a Single Switch Setup: Connect one of the two wires from the wall to the black wire from the switch timer, using the twist connectors provided. Connect the other wire from the wall to the blue wire from the switch timer, using the twist connectors provided. NOTE: The RED wire is not used in single-switch installations. Cap with a twist connector.
Connect the GREEN wire to the grounding screw in the box. If a plastic box, connect to ground as supplied. Make sure all twist connectors are tight
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/st01c%20-%20english.ashx
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I don't know how to hook my computer mouse and my key board up?
Since you didn't mention the keyboard or mouse connector type, i can't figure out what exactly mean, but if they are ps2 type connectors, then take a look at the picture below; and follow simple instructions..fc95c5b.jpg
Connect/plug in your mouse on the Green port with the corresponding connectors (pins) and connect/plug in your Keyboard on the Purpe port.
I hope this helps..
Good luck.
Thanks for using FixYa.
Jun 22, 2010 | Dell OptiPlex GX150 PC Desktop
How Can I Get My Ps2 To Go Online What Parts Are Needed
You need the Network Adapter and you have to sign up and pay money/ month
http://au.ps2.ign.com/articles/366/366021p1.html
f you are hooking it up to a DSL cable/modem,
1. Remove the sticker covering the network connector on the Network Adaptor and
plug your Ethernet cable in the connector labeled NETWORK.
2. Plug the AC power cord for the PlayStation2 system into an electrical outlet.
3. Turn on the PlayStation2 system and start the Network Adaptor Start-up Disc.
If you are hooking it up to a router:
1. Remove the sticker covering the network connector of the Network Adaptor.
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to an available LAN port of the router.
3. Connect the WAN port of the router to the DSL or cable modem.
4. Connect a personal computer (not pictured) to an available LAN port of the
router. Use a web browser on the PC to set up the router to reach the
Internet.
5. Follow the specific instructions that come with the router. There is no additional installation for switches.
If you are hooking it up to a LAN:
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to a wireless Ethernet bridge.
3. Connect the WAN port of the wireless router to the DSL or cable modem.
4. Connect a personal computer to the router. Use a web browser on
the PC to set up the router to reach the Internet.
For pictures, see the thread here:
http://www.funadvice.com/r/3js7klmkua
May 20, 2010 | Sony PlayStation 2 Slimline Console
Instructions for the New bright 384 holiday express
Not sure what instructions you need, but the setup is very simple.
1. Put your track together
2. Attach the track power connector by slipping it under the track and pushing, then lift up the other side. This will make the two metal contacts connect to the track.
3. Plug the connector from the power pack into the track module (It should only go one way)
4. Plug the control box (looks like a telephone cord) into the track module, Will only go one way
5. Place the locomotive on the track.
6. Place the Treetop Tender on the track (you need both to make it run)
7. Connect the large connector from the treetop tender to the loco
8. Turn on the command module and press forward ...
You should now be running in circles ...
Hope this helps...
Dec 15, 2009 | New Bright 384 Holiday Express Animated...
Instructions for replacing 1997 Jeep Wrangler 6cyl
Its an easy job! Disconnect the battery first! That's very importand! Then disconnect the wiring pack from the ECU. Some models are equipt with snap-systems, other with a screw-system to remove the wiring connector from the ECU. If done, there are three or four screws that hold the ECU in place with the body. Remove the screws and you hold the ECU in your hands. To buy a new or rebuilt ECU, reffer to the numbers shown on the label at your Wranglers ECU in combination with the V.I.N. To connect the new ECU with the wiring pack, be careful with the connector! You need to put him in the right position to connect with the ECU. Do it slow and make sure the connector fits to all points. Otherwise you'll bake some contacts inside the connector.
Oct 23, 2009 | 1997 Jeep Wrangler
How to connect to pc tru data cable
Install active sync from the CD that came along with your phone and connect your phone to the usb connector through the cable, then follow on screen instruction.
If you do not have the cd use the following link to download latest active sync
instructions and link to active sync
http://www.htcwiki.com/page/ActiveSync+Installation
Jul 17, 2009 | HTC Touch P3452 Smartphone
Connecting Macbook with a compaq MP1400 digital projector
You're going to need a conversion dongle that goes from the Mini-DVI to VGA.
Then:
  1. Connect one end of the projector signal cable to the Video Graphics Array (VGA) connector on the projector.
  2. Connect the other end of the projector signal cable to the Digital Video Interface (DVI) connector or VGA connector on the notebook computer and tighten the screws.
  3. Connect the projector power cord to the power cord connector on the projector.
  4. Connect the other end of the power cord to an electrical outlet that is easily accessible and close to the projector.
  5. Turn on the projector first, then turn on the computer.
Nov 09, 2008 | Computers & Internet
My sony PS3 wont connect to the net , (error 80710723 ) what does it mean ?
I believe you can connect it directly (via CAT 5 cable with a RJ45 connector from a router), or via WiFi, if you have wireless internet available where you are trying to connect.
FYI the CAT 5/RJ45 connector looks like a male phone connector, just a little wider (there should be a female RJ45 on your PS3 console). Also to connect to a wireless router, you should find instructions in your PS3 manual. If you need better information, please provide us with more details.
I hope this helps, and Good Luck.
Feb 28, 2008 | Sony Playstation 3 (PS3) Console
ASUS GeForce GTX 770 GTX770-DC2OC-2GD5 Video Card Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
