Question about Hitachi Cameras
What is the use if my USB cable for my Hitachi HBC161E
Can I use my USB to access camera information stored on it's hard drive.
  • 275 Answers
SOURCE: pictures on hard drive
You can remove the memory chip and put into the slot in your computer, if it has one. Be careful not to touch the gold connectors on the card, any static can wipe out the card.
Posted on Mar 07, 2010
SOURCE: Have a new camera...no idea
Hi, does your pc have a photo program, this should detect the camera connection.
If not there are various free programs available on the internet,
I use Picasa2 you get this on google.
Download this & then connect your camera it will do the rest.
Posted on Jun 11, 2008
welcomejee
  • 10594 Answers
SOURCE: New camera...no idea how to
Can u spacify Model & Make of ur camera?
futureloginn
  • 734 Answers
SOURCE: hitachi external hard drive recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
SOURCE: Problem with Hitachi 1TB external hard drive
Most likely you just burnt up the adaptor. You can order another one from Hitachi.
The data is probably still intact on the drive itself.
You can connect it to your computer with an adapter that plugs into the drive itself and the usb port on your computer. It then shows up as a drive letter as normal.
You can buy these sata to usb adapters at most computer stores for around $25. Tiger has a nice selection:
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=sata%20to%20usb%20adapter
I would pick one with an external power supply. It also connects to your hd. The ends are keyed so you can't miss-plug them.
Or find a local computer tech (most have this cable in our toolkit) and he probably will copy your data in a few minutes for you.
Posted on Mar 05, 2009
Hitachi
open the case , take out the drive , attache it to a computer internally ,youll need a cable or borrow you cd's cable, turn drive on in the bios to see drive ,save , boot an let windows load it , now does it come up as a drive letter an can you scan fix it . right clik that letter , properties , scan an fix. now thats assuming the drives have windows compatible sectoring an software that formatted it for your data to hold on it.
if you get an error before you get into windows then the drive has likely died in one of many ways.
Jun 25, 2014 | Hitachi 2TB Touro Desk USB 3.0 External...
Hitachi hbc161e manual
I took photo's without a memory card in the camera (Hitachi HBC 161E) and thinking i could retreiv them using my usb cable connected the me pc. However when connected the camera remains out of view to the computer. How do I retrieve my pictures
Apr 24, 2013 | Video Cameras
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
My hard drive is not being recognize
Jan 06, 2013 | Computers & Internet
I dropped Hitachi external drive...
If you have no backup and your drive is damaged, that is it, no data.
Plug the usb in with your drive, leave your computer looking for the drive. If windows, it may take some time. If Mac it won't be long. If neither can see it, the TOC is damaged and it will need a computer engineer to try and recover the drive.
May 28, 2017 | SimpleTech by Hitachi SimpleDrive Rev. 3...
I just got the HITACHI SimpleDrive 1TB USB 2.0 External Hard Drive HSD1000 recently and downloaded some files from a mac on to it, now I'm trying to access the information from it from a Windows &...
The external hard disk must be formated in a file system that both the pc and the mac can use - best is FAT32. In your case the file system that the mac put on the disk is incompatible with the pc.
Make sure the files you want to move are still on the mac (if not copy them back from the disk), plug the disk in the pc and format it there in FAT32 (don't use the quick option), plug it in the mac and copy the files and unmount the disk before disconnecting it from the USB connector. Now you can put it in the pc - in there always use the Safely disconnect icon, don't just yank out the cable.
Aug 15, 2011 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
Where do i access drivers for my hitachi hdc-1005e digital camera. the OS is Windows 7
On Windows 7 you do not require a driver for this camera. Switch the camera on, plug it into the USB cable, plug the other end of the cable into a spare USB port, on the camera LCD screen, select "PC", Windows will then see your camera as a portable drive, simply copy the photos from that drive into your photo folder.
Jul 11, 2011 | Hitachi Cameras
Hard drive 'beeps' and not recognised by pc . Tried cable and pc all fine .
You can't see Hitachi from your PC, right? If you have 2nd pc, try with second pc to see if it recognizes. Or reboot PC to see if it helps. Some cases, the external hard drive is bad.
May 13, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
I can not access my hard drive all of a sudden
Please check the USB cable and the USB connector at hard drive enclosure, and also if it uses external power supply, check if any power indicator turns on when you connect it to a power outlet.
Mar 03, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
Cameras Logo
59 people viewed this question
Top Hitachi Cameras Experts
Parshiv Luthra
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
