Question about Exercise & Fitness
Avanti treadmill is coming up with error 4, and flashing 68, I have lubed the deck, and have taken off the cover to fix the reed switch, but I can not find a reed switch. I'm over it, can someone please help... Thanks...
    Top Expert:
  • 12,223 Answers
See the diagram attached for REED switch. test it for open or faulty, clean it, and tight the connector very well. God bless you
Avanti treadmill is coming up with error 4, and fl - 40df33cf-cf85-4927-899d-6e42d0d9946f.gif
Posted on Jul 15, 2013
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Avanti AT 380 gets an error code 68
556a61de-db92-4886-91ce-2e6c36b807f6.gifyou must LUBE the deck belt, front rollers and rear. This happen because the electronic system , shut down for to protect the system.
see the video and proceed according. See the diagram for REED switch clean it, test for open or faulty, tight the connector very well.
God bless you
Posted on Jun 16, 2013
Testimonial: "Hi Ernesto, thanks for your reply. My Avanti AT380 treadmill does not have a REED Switch next to the front pulley. I had alook at the manual and can't find it. Was just wondering what else can cause the error 68 code. So frustrating to use the treadmill. Some days no issues at all...."
God bless you
Jun 16, 2013 | Avanti Fitness AT380 Treadmill
Treadmill error code 68
f91790db-4de9-486c-b68a-34e9745503d7.gifplease download the owner manual for identify the REED switch. go www.fitness.manualsonline.com
God bless you
Avanti 928 Treadmill U8 error
try to LUBE the deck belt, with silicones or wax, . If the problem persist TIME to replace the old deck board.
However, adjust The REED switch + speed sensor.. See the owner manual for to locatea. otherwise download free from
www.fitnessmanualsonline.com
God bless you
May 20, 2013 | Bowflex Treadmill Series 7
Avanti treadmill 928
firts LUBE the deck belt with silicone or wax. Read you manual. If the problem persist, TIME to replace the old deck board.
However adjust the REED swticha+ speed sensor. see your manual
God bless you
May 20, 2013 | Exercise & Fitness
Lifestyle treadmill error
LUBE the deck belt,this happens because the lack of maintenance
2) LUBE the rollers bearing too, very important.
3) adjust the speed sensor see the diagram attached, clean it, and tight the plug.
4) adjus the REED swtich, see the diagram clean it, and plug the connect very well.
5) Try after you did the adjustment RUN the software calibration for diagnostic, troubleshooting, and fix it.
God bless you
Oct 07, 2012 | Life Fitness Exercise & Fitness
I purchased a avanti 380 treadmill from eBay. Was running perfect so we put it in our trailer and brought it home. When we plugged it in it had LJE1 displayed in the time display and flashes 68 in th
Adjust the REED switch, see the diagram, clean it, tight the connector very well
2) replace the battery well, clean the contacts, retight the spring contacts with pliers very well.
and proof again. God bless you
Sep 06, 2012 | Avanti Fitness AT380 Treadmill
I have a Avanti 380 when it is turned on LJE1 is displayed in the display and the number 68 flashes in the MPH display
adjust the REED switch, clean it, tight the connector very well.
see the diagram
2) replace battery, clean the contacts batteries, retight the springs contacts batteries, and clean it.
Proof again. try to RUN after you did the steps before, the software diagnostic, for troubleshooting, and fix it.
God bless you
How do i fix my treadmill
RUN the software calibration for diagnose, troubleshooting and fix it.
adjust the reed switch see diagram +adjust the speed sensor clean and tight the wires connector very well.
2) test the drive belt motor, 3) LUBE THE deck belt,+4) Lube the rollers bearing 5) test the motor +main board control for faulty. see the diagram attached.
God bless you
Jul 19, 2012 | Exercise & Fitness
The control panal on my weslo cadence treadmill is not working
Do the following :
1) Lube the deck belt follow the instruction manual, maybe the deck is worn.
2) Lube the roller bearing.
3) Align the deck belt.
4) Test the drive bel.
5) Test the input voltage motor, if there are the motor need repair.
6) Test the output voltage board, for input voltage motor, if there are not The board is faulyt.
7) Run the software calibration for diagose, troubleshooting, and fix it, follow the steps from instruction manual.
8) Adjust the Reed switch, clean, and tight the connector very well.
sincerely. God bless you.
May 06, 2012 | Exercise & Fitness
When turned on right hand display comes up with 51 then flashes with the number 68. Dead man button works but not any of the controls. Alex
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 11_30_2011_12_46_08_am.gif
Try to tight the keypanel flexible cable vs Display Board and then tight the connector from display board vs Main controller board(lower board) and will be a good idea spray with contact cleaner the keypanel with carefully and patience.
Finally you will have 2 options if the problem persist: 1) display board faulty or 2) main controller board faulty. See. the block diagram how the main controller board has 90% of function in any treadmills.
Jul 14, 2011 | Avanti Fitness AT380 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
