Question about Bushnell Optics
How do i re-mount the rear lens of my scope - Bushnell Optics
  • 115 Answers
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Posted on Mar 13, 2014
I have a diana 177 air rifle that keeps going out of sight every 2 shots,could the inner barrel be broken?
does it have a scope or iron sights? If it has a scope make sure your scope mounts are tight. you may have a loose lens inside your scope. Not likely that you have a broken barrel
Jan 17, 2013 | Washing Machines
Elevation adjustments do not seem to hold or the scope moves slowly over time. I'm not certain. Windage works fine. Looked at manual on the web and the scope must have changed design because not...
Most of the time a scope that creeps off its zero, has a loose mount screw and or loose mounting ring. Check the mounts all screws. Some times the opposite is true. The mounts are to tight and in a bind. Then during firing the receiver heats up an tweaks the scope enough to cause creep. If the scope is always on zero when cold and creeps off after a few shots, she is in a bind. Make all adjustments to the scope base and rings with a cold gun. Loosen the front ring screws first then re-tighten then loosen the rear doing the same. Then try and re-zero the gun. If the gun never comes back to zero, you end one day shooting hi to the right and try again the next day shooting in the same spot try to re-tighten all screws. Screws from mount to gun then scope rings to scope body.
Jan 02, 2011 | Nikon 39x40 Matte Nikoplex Buckmaster...
In the process of zeroing the scope in I noticed that I can adjust the elevation of the scope up but can't set the adjustment down as far as I need to go in order to be sighted in. This is the first time...
There are a few things that it could be. Make sure you have the scope mounted with the elevation screw on top and the windage screw on the right side. Next, carefully check the distance of the scope from the receiver. If the mounts aren't exactly the same, the scope could be tilted upward. Try switching the front and rear mounts. Make sure you don't have either of the mounts on backwards. Make sure the scope is built for the caliber you are shooting.
If none of these fix your problem, Leupold scopes are guaranteed for life.
Oct 07, 2010 | Leupold Rifleman Rifle Scopes BHK290
I bought a used Tasco Galaxsee 45-060525 for my next door neighbor's young boys who are home-schooled to study astronomy. The lens are all foggy/cloudy. Any suggestions?
Wish you DID NOT buy this scope. Tasco, Bushnell, are both what we call "department store" telescopes.
Also the mount is called an equatorial mount. It must be polar aligned in order to use it. Read my TIP on polar alignment on my profile page.
The eyepieces can be cleaned with any eyeglass cleaning kit or photographic lens cleaning kit from a camera store. Be gentle when cleaning.
Next time buy them a scope like this one called a Dobsonian mounted reflector.
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942
Read these two web sites:
http://www.texasastro.org/telescope.php
http://www.texasastro.org/mounts.php
Aug 31, 2010 | Tasco Galaxsee 45-060675 Telescope
I need to make an elevation adjustment; the cross-hair adjustment is not enough . Perhaps a more gross adjstment is possible where the ring mounts are located?
the easy way to get a little more ajustment of about 4-5 inches at 100 yds is to,,,cut up a 3 bit's of 35mm colour film to fit under the scope,,undo the rear scope top mount and lift the eye bell off its mount,,now slip the 3 bits of 35mm film under the scope body and reclamp the top mount cap,,,dont forse it up to tight ,,this will lift the point of aim
at least 4 or 5 inches at 100 yds
Aug 24, 2010 | Leupold 54120 2-7x33mm European 30mm Matte...
The is on a 270 it still shooting to the left and there is no more adjustment
the scope mounts are no good then,,,,,but you could try this,,,
cut up 3 bits of 35mm camera film so they will slide behind the scope mount undo the rear scope mount cap (eye end) and slip the film strips into the right side of the mount so they push the rear of the scope over to the left hand side of the mount (as you look at it from the **** end) then nip up the mount cap bolts,,,
this will move the point of aim well over to the "right" some thing like 4-5 inches at 100yds if this still dont line you up,,,
change the scope mounts
Aug 22, 2010 | Bushnell .22 Rimfire 3-9x32 Rifle Scope...
I used all of the elevation adjustment on 3-9-50mm scope and my 22 rifle still shoots low at 25 yards
its a bad mount thats doing this,,,you can get over it easly by letting off the rear top mount of the scope (the mount near your eye) and pushing under your scope a strip of 35mm film this will lift the eye end of the scope giving you more range,,(elevation) only put 2 or 3 strips of film under the scope any more that this could bend the scope tube when you tighten it up
but a strip of film is about 25th of an inch and 1th will give you 1/4 of an inch at 100 yds ie:1 click! so you should easly get 10 inches at 100 yds or more with 3 strips of 35mm film under the scope even with bullet drop, the only other way to sort this out is to buy an adjusterbal mount witch is very pricy and 35mm film is cheaper, i do this all the time with my scopes
Nov 21, 2009 | Tasco Scope Guide Quickly Zeroing Rifle...
Elevation is turned all the way up and at 50ytards
this is a common fault with fitting cheep mounts on your rifle,,
a nikon scope is realy for "air rifles" but having sead that there very strong scopes, i have 4 of them all fitted on full bore rifles,,308,(7.62) .303 british enfield, .22-250 and a 357 mag rifle? and none of them have shook apart yet! and i found that on a full bore they do shoot low,,,to get over this problem you could change the mounts to the ajustable type witch is pricy,,or a cheep way out is to pack the bottom of the rear scope mount out with a strip of 35mm film,,(the rear being the end you look throw),you only need to life the rear end of your scope 25th of an inch to rise its point of impact by 6" inchs at 100 yds as the nikon scope is one click (1 thou of an inch) = 1/4 of an inch at 100 yds so 25 thou will raze it by 6.25 inches (- bullet drop!) just undo the scews that hold down the rear of the scope and slip a bit of old 35mm film under the scope then nip the scews back up again and try it out,,,if its still low put in a bit more packing,,,but you can only get about 4 bits of film in before its likley to bend the scope tube!!! mind you with 4 bit under it you will be shooting at the moon??? its much cheeper that ajustable mounts,, all my scopes are packed out like this and they dont creep or slide or loos point of aim even after 300 rounds in a day?
Nov 18, 2009 | Nikon Optics
Optics Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
