Question about Sharp sh530u unlocked gsm phone
How to hard reset sharp sh530u when the phone is locked due to too many pattern attempts and I can't open the phone even if I KNOW MY GOOGLE ACCOUNT because I can't connect to wifi or data network. Any particular buttons to press? Please help.
  • 250 Answers
Switch off your phone and Do a restart
- Get your data cable and connect to the PC
- Suddenly you will see the "Mass Storage Mode" Selection page.
- Then you may able to go the upper task menu and you may able to activate Wi-Fi or Data.
Thereafter you can unlock the phone using the Google credentials.
This was worked for me several times.
Posted on Jul 15, 2013
Testimonial: "Thanks for the info. But, the same didn't work out. I did exactly what you mentioned but I just couldn't pull down the upper menu. The phone doesn't respond. I can only touch emergency call button and google credentials space. Just for your info., my phone's USB Debugging is not as well activated so my pc can't have access on the phone. It can be recognized but I can't access the contents. Hope there is another way. Thanks a lot."
I have an lg optimus straight talk phone. I had too many pattern attempts and don't know the email and password to unlock it. Tried a hard reset with the volume, home, and power button, but it didn't work....
Hard reset LG Optimus V VM670 full reset
WARNING: All of your data will be lost!
1. Turn the power off.
2. Press and hold the following keys for over 5 seconds: VOLUME DOWN key mxiqtgowitk7gwzqbxyhdcltfs16ozyouevveokanftkdtnwwymj9scskqm0ieh5eq5ckaujhqmaoieaoif3fpipvbh8k+pbkkoaaaaasuvork5cyii= + HOME opgbfz5a5gqhftj+tmuaaaaaelftksuqmcc + POWER/LOCK bfcjfp4fns6dfvyu0xyaaaaasuvork5cyii=.
3. When the power turns on, release these keys.
Settings > Privacy > Personal data >Factory Data Reset
If you've entered the wrong information 5 times, you will need to wait 30
seconds before you can attempt again.
When you can't recall your unlock Pattern, PIN or Password:
If you've set up a Google account on the device, tap the Forgot pattern? button. You will be able to unlock the device with your Google account user
name and password.
If you haven't created a Google account on the device, you will need to perform a factory reset.
(CAUTION! If you perform a factory reset, all user applications and user data will be deleted. Please remember to back up any
important data before performing a factory reset.)
Tony
May 30, 2014 | Cell Phones
Unlock code
First solution is to use Google account associated with mobile.You need to log in into your Google account and then you can disable or change the pattern lock.Internet (mobile data) on your mobile should be working otherwise you need access to WiFi to do that.If your mobile is not connecting with internet then you have to go for second solution.
Too Many Pattern Attempts
If WiFi or mobile data is Off on your mobile then you can't authenticate online to unlock your device.You can enable WiFi as well as mobile data by connecting your mobile with Android Debug Bridge (ADB). This method requires USB Debugging feature enabled which is under 'Developer options' of your device.
Second solution to overcome "Too Many Pattern Attempts" problem is to format the mobile device.You need to make hard reset of your mobile to overcome pattern lock problem.For most of the Android devices ,you can hard reset the device by pressing POWER + VOLUME + HOME button simultaneously.Please remember that all your data (images ,music files , videos and contacts saved in mobile ) will lost during hard reset and your phone will be restored to factory setting.
Let me know if you didn't find hard reset code/method for your mobile.I will find it for you.
Third solution is to use desktop app.You need to know username and password of Google account associated with your mobile device.Name of the app is Screen Lock Bypass Pro. You can download it in Google store.Install this app on your device and you can bypass the pattern lock.
Aug 30, 2013 | Samsung Galaxy Ace GT-S5830
I cant open my samsung galaxy s2 due to too many pattern attempts my daughter try to open more times thats why it unlock and try to open it by putting - I wanted to ask you what im goiing to do if my...
Typically when a mobile device is locked, it wants the original e-mail account name and password it was setup with. If you can log into your account at https://mail.google.com/ that's good, but it doesn't guarantee it's the same account the phone is using or the original password used.
If you don't remember the username and the account was properly setup at creation time, you can recover the name using "I forgot my username" here: http://support.google.com/mail/bin/answer.py?hl=en&answer=46346 And here's a trick to recover an account name on an Android device: https://productforums.google.com/d/topic/gmail/ydNElvUjJVU/discussion
If you have the username, the following will help with the process to recover the account by resetting the password: http://gmailaccountrecovery.blogspot.com/
BUT... A recovered account won't have the original password which is what the device needs to be unlocked. In that case the device will probably need to have a factory reset done (read the owner's manual for instructions) and then setup again with an e-mail account (be sure to write the information down this time). If it's setup with the recovered e-mail account, any purchased apps and synced data should be restored. If a new account needs to be created, all previous information will be lost.
We Are Here To Help !!!
Donald Deane MCSE,ASE,CPO
Aug 11, 2017 | Cell Phones
I can attempt my lg gt540 mobile pattern code wrong then mobile is locked.so plz help me
dear friend,
visit unlock-zone.com for the help
hope this will do
enjoy & cheers
Jan 24, 2011 | LG GT540 Cell Phone
Pettern lock
To unlock the pattern screen lock without signing in with your Google account You need to repair the software of the phone.
The steps to repair the phone are the following:
1. On the computer: Start PC Companion™.
2. On thecomputer: In the Support Zone™ descriptor, in the Software Updatesection click Start > (Repair) and follow the instructions on the PCmonitor screen.
3. Turn off the phone.
4. Connect the USB cable to your computer.
5. On the phone: Press and hold down Back key and connect the USB cable to the phone.
6. Follow the instructions on the screen.
Note : The software in your phone will be replaced. All personal data stored in your phone will be lost.
There is also a way to unlock the pattern screen lock by signing in with your Google account.
1. After 30 seconds, tap Forgot pattern?
2. You need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
3. Tap the username field and enter the primary Google account user name.
4. Tap the password field and enter the primary Google account password.
5. Draw a new unlock pattern and tap Continue .
6. Draw the new unlock pattern again and tap Continue .
If these options are not available to you, please describe preciselywhat you see when attempting to connect to your PC and use PCCompanion.
Jun 05, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Sharp sh530u unlocked gsm phone Logo
2,843 people viewed this question
Top Sharp Cell Phones Experts
Computer Repairing
Computer Repairing
Daniel Dollive
Daniel Dollive
ivan georgiev
ivan georgiev
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
