Question about Acer Extensa 5620-4677 Notebook
The computer beeps continually while running
The power pack was recently repaired by replacing some parts. the problem began there after
  • 156 Answers
Dell inspiron m5030 wont boot, 7 post beeps continuously
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove new hardware If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device. Remove any disks or USB devices Remove any disks, CD's, DVD's that are in the computer and if any USB devices (Ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes. Disconnect external devices. Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs. Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot. Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable. All disk drives should have a data cable and power cable connected to them. Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers. Hope this helps.
Jan 06, 2013 | Dell Inspiron Computers & Internet
Couple days ago my car began running realy rough and service engine light began flashing. It was alredy on due to needing a o2 sensor (after cat converter) so i took it to part store and computer read...
Yup! It sounds to me like you have been told correctly! This is the very reason that I preach to people that it is NEVER OK to continue operating a vehicle with the Check Engine light on. The Check Engine light has one mission in life. Its purpose is to let you know that there is a problem in your engine control system that can damage your catalytic converters. Ignoring this light and continuing to operate the vehicle anyway causes the problem that you are now experiencing.
What to do??? Get up off of the BIG BUCKS and replace the high-dollar catalytic converter that has been destroyed. Then diagnose and repair ALL fdault codes in your engine control system so you don't destroy another one.
Jul 18, 2011 | Nissan Altima Cars & Trucks
About 3 times a day the external battery pack for the computer beeps really fast. Then stops.
Most "desktop" computers do NOT have an exernal battery pack. If your does, that's OK.
The "beeps" probably occur when the AC power from the wall-outlet is interrupted (or is cut-off). The charge in the battery continues to supply power to your computer -- so, your computer does NOT crash.
Jan 13, 2010 | HP Pavilion M9040N Elite Desktop PC
Fujitsu lifebook n5010 notebook won't reboot i let the battery run out while working. next day, turned on three loud beeps, then three loud beeps then fan runs but no display on the screen. power off,...
Okay, sounds bad.
However, take out the battery from the laptop and remove mains lead. Go and make tea! Then, drink it. Once you have complete this task.
Plug in the AC lead ONLY into the laptop and then try to power it on.
You should see lights on the Hard Disk LED or hear a beep. If you see them but nothing on the screen at all when booting then the capacitor pack has probably gone on the screen. This is not an expensive part, but you do need to know what you are doing to replace it. Think it time to give it to the workshop or ask IT bod to look at it for you.
Oct 26, 2017 | Fujitsu Siemens Lifebook N5010 Notebook
Sub continuously thumps when stereo is on
The remote on might be suppling intermitten power. Try jumping the remote on from the power wire
or...
If you've abused it, It may be going straight DC output (if that's the case you need to repair or replace the amp)
Apr 29, 2009 | Car Audio & Video
Exhaust emission light Golf 1.6 S 2001
when the engine light flashes its telling you the car is miss firing and from your description it was...even though you had coil packs replaced that is by far the most likley cause .if they were genuine parts you will have unlimited milage 2 year warranty.get the fault code read to find out what cylider the misfire was on and change that coil pack..
Feb 19, 2009 | 2001 Volkswagen Golf
Computer beeps three times and will not start
Clear CMOS/ Remove battery for 10 minutes, reinstall battery & wait for another 10 minutes before turn on. Three Beeps means RAM is defective/ not detected.
Jun 27, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Acer Aspire 5110
Does your computer make the beeping sounds on boot up. If so, this means that a drive is corrupt and it's not loading the system driver files or is not seeing your hardware to boot up..
Are you running windows xp?
Have you tried running a system repair using your windows xp cd?
That works by putting in your xp cd...booting to the cd....the first window you come too will ask you the basic, agree to terms, press f8 to agree...then to the next screen.
There it will have 2 options...install a fresh copy of windows
Repair a version of windows...choose repair
Allow the repair to finish...and restart....if the repair was successful, your computer will restart normally...
Let me know if this works.....and how many beeps you are getting
~~Jasta~~
Mar 29, 2008 | Acer Aspire 5100 Notebook
Acer Extensa 5620-4677 Notebook Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
