Question about Pelco Spectra Dome Iv 4 Day / Night Ptz High Res Color Camera 35x Zoom
No camera control
Upgraded to Spectra IV PTZ cameras, utilizing IFS SM VDT 1535WDM and IFS SM VRD 1535WDM-R3 connected to Pelco DVR DX8100, Pelco Matrix Switcher/Controller CM6800, Pelco Digital Color Duplexer and controlled by Pelco KBD960 Intelligent Keyboard controller - we get a picture but have no control what so ever. Has anyone had this issue - if so what is the solution?
4 Suggested Answers
SOURCE: How delete recorded movies in a Pelco DX8100
Contact the manufacturer at (800)289-9100 x 2781 for instructions on how to reformat the drive.
Posted on Dec 31, 2008
  • 7 Answers
SOURCE: Pelco Spectra III PTZ camera wrong fuse?
It is replaceable, as long as no harm has come to the rest of the camera.
Posted on Jun 15, 2009
SOURCE: Why the Pelco spectro mini PTZ camera getting stuck(not rotating)
Normallay when getting stuck in Mini dome, we found 2 common problem.
1. Take out the cover and test rotating. Dome are deflect and causing resistance between camera dome and bubble.
2. The 2 screw are too tight. Loosen abit and try rotate.
Posted on May 29, 2010
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
Spin out of control
Reset the power to the camera and test first.
If it worked before you may have a wiring fault... or if it is new or someone tampered with it, the baud rate settings or protocol setting might have changed.
Apr 03, 2012 | Pelco CONTROLLER MATRIX- PTZ CONTROL
Does it supports any brand of cctv cameras or will there be any incompatibility with same brand..
It support all brand of CCTV.
for PTZ CCTV, It has to have the Pelco protocol so the WJ-HD716 can control the camera.
in that case, the connection will use the RS485.
Oct 19, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
I have a Pelco Spectra mini in a warehouse, we replaced the previous camera with this new one but the PTZ function does not work. The old camera worked for while and stopped. We moved the new one to...
Hi. Did you call Pelco's customer support? They should be able to talk you through troubleshooting the camera to at least determine if this is a defective camera or not.
Aug 18, 2009 | Cameras
On the monitor there is a small little camera
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is not coming from the camera...They don't put anything like that out. Check the OSD settings of the device the video is going into. If there is On Screen Display setting with in the device (DVR, MUX, Matrix Switch, ECT)....if that doesn’t work then check the monitor menu to see if its a display feature you can turn off...good luck and let me know if this helps just remember the pelco camera will not push any graphic out except in the case of a PTZ where you will see the Protocol information text...
Jul 09, 2009 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
Jun 03, 2009 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
My pelco DVXe dvr display is at minimum not 32 bit cant see pics
boot into bios and set your display for vga mode. At least that worked for me
Apr 09, 2009 | Pelco Home Security
Mar 14, 2009 | Pelco SD53C22 Smw 0 Spectra III Se White...
Dec 25, 2008 | Pelco CM9760 (CM9760VMC8) Video Matrix...
Pelco Spectra Dome Iv 4 Day / Night Ptz High Res Color Camera 35x Zoom Logo
Top Pelco Video Cameras Experts
Are you a Pelco Video Camera Expert? Answer questions, earn points and help others
