Question about Music
Motley crue vox amp settings - Music
I have a vox vt40 and the light for the power comes on bit there is no sound. I talked to someone with the same amp and they said there is a clip that switches on the tube that tends to go out with this...
If your amp isn't producing signal, your best bet is to take it into a local Vox autorized repair shop. There are leathel voltages involved and if you're not an experienced tech, you can get hurt, not to mention screwing to amp up worse. Here's a link to the Vox contact page http://www.voxamps.com/contactus
And one to find the list of Vox repair shops.
Korg USA Musical Instruments
Feb 11, 2015 | VOX Music
Is it possible to lower the VOX VT50 transfo outgoing voltage?
bulbs have tolerance, that means it can work with + or - 6.3v just use the 7.6v which a diffrence of 1.is ok for it to work.
Jun 27, 2014 | VOX Amplification Vox Valvetronix VT50...
Vox vt40 factory reset
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Apr 12, 2014 | VOX Amplification Vox VT40+ Valvetronix...
Vox vt40+
that is because it is two different output channels. eventually you will blow the speaker or your amp. It wasn't designed to handle the impedance of an external speaker through the stereo
headphone jack. Are you sure that your speaker is hooked up or plugged in?
Mar 30, 2014 | VOX Amplification Vox VT40+ Valvetronix...
I have a vox valvetronic 50, which keeps blowing fuses as soon as it is switched on and leaves a burning smell. any ideas?
One or more parts in the power supply section is defective. I would recommend taking/sending the unit to a repair depot.
Oct 20, 2013 | VOX Amplification Vox VT30 Valvetronix...
Vox mini3 hiss or white noise when reverb or delay is selected.
The way I've found this amp works is it always needs a certain amount of "Gain" from the gain nob in order to produce any sound.Unfortunately the more gain the more hiss and crunch at least thats been my experience, it could also be you have one of the filters "guitar sounds" left on.The guitar sounds nob has to be left on clean to attain pure clean.There could also be a connection problem.I have this at the moment.I have to bend my wire in the right place to keep the thing going.Another issue I have with his amp is its been replaced my first one just conked out completely I couldn't get the cash back when I asked so I just got another one.This new ones been fine but not without hiss.I think its a hissy amp I hate to say it.Not the best amp by a long shot.
Oct 13, 2011 | VOX Amplification Vox MINI 3 Amp Combo
I have a VOX NT15. When switched to Triode ( 7,5 W ) mode, my amp generates quite loud buzzing sound. The loudness of this sound is on the same level, no matter if the volume is switched to minimum or...
You LIKELY have a bad filter capacitor. The additional load of the Triode load is probably dragging the supply causing flattopping and the power supply ripple frequency to come through. Have the unit serviced.
Jul 26, 2011 | VOX Amplification Vox Night Train Amp Head
Music Logo
24 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
