Question about Rinnai EnergySaver 556 Air Conditioner
Rinnai 556f energysaver 431ftr
Flashing error code '11'
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai 556F stuck on Low and will not produce heat
The Low code indicates that the heater did not start because of lack of gas or that the flame rod did not sense enough heat. Make sure all gas valves are on and if you use propane gas, that it has gas in the tank.
Assuming all gas is on, you will need to remove the front cover by first pulling off the very bottom trim piece. This is located below the louvers and by grasping both left and right sides of this trim, pull toward you. It is just held in place by little clips. Now taking a very new #2 Philips head screwdriver, remove 2 screws found on the extreme left louvered section of the front. Then 2 more on the extreme right. Two more near the center of the louvers. Now I think there are two more holding the bottom in. Gently move back and forth the front panel starting at the bottom and work out the clips at the top just below the instrument area. Be careful to not break any of the clips at the top. With the front off, at about the 5 o'clock position you will see a very small round hole with glass over it. Start the heater and look to see if it ignites and stays on for a second or two. If it does but goes out very quickly, you may have a corroded flame sensor. The flame sensor is located by looking into the small hole and up to the 11 o'clock position. All it is is a probe that sticks down. The only way to get to it is by removing the small window section of the heater and use a wire brush used to clean a gun and brush it. Or very gently take a thin but long regular screwdriver and scrape off the probe. Be careful not to damage the fragile white gasket when taking off the sight port.
If the heater never started, you have a restriction in the gas train. Typically I find that spiders make a nest inside the gas burner because the bugs they eat likes the gas smell. The only way to get to their web is to remove the burner from the unit and clean it. This is not an easy part to remove and suggest you call a technician.
Good Luck!
Posted on Nov 04, 2007
early1234
  • 871 Answers
SOURCE: Heater and Air Conditioner
yes it does
check here... here
Posted on Apr 01, 2008
SOURCE: Rinnai EnergySaver 556F Heater flashes
I'm picking up a faint propane scent when the heater is completely turned off. When I turn the heater on it lights fine so I don't suspect it's the pilot light. Is this an issue with the installation of the fuel line, or could it still be the pilot? Any ideas on troubleshooting the source?
Posted on May 26, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Rinnai Energysaver 556F
The heater will have some error codes stored in it. To retrieve them get an assistant to write down the codes as you see them. They come quickly. OK to get the codes, push down on the Economy button and the up arrow and down arrow at the same time. Hold for three seconds. It will take three fingers to do this. Once you get the error codes, look in your owners manual to diagnose.
Posted on Feb 20, 2009
SOURCE: Rinnai energysaver 556FTR filter light
You need to remove the filter and vacuum it. Recommended cleaning once per week.
Posted on Jul 25, 2009
My rinnai energysaver 431ftr keeps coming up with error 53. How do I fix this please?
Here is a link to the Manuel you should be able to find the error in here.
http://www.rinnai.us/documentation/downloads/Owners_Manual_431FA.pdf
If you cant handle the problem yourslef you may want to call a service professional.
AC Repair West Palm Beach
Apr 26, 2015 | Rinnai Heating & Cooling
Rinnai DV Propain Heater 556F
Sounds like the relay might be going bad and needs to be replaced
Apr 10, 2008 | Rinnai EnergySaver 556 Air Conditioner
I have a rinnai energysaver 556f heater and the "On" buttons keeps flashing and it feels like it's blowing cold air. The "LO" button keeps flashing as well. What does this mean?
It is telling you that there is an error code stored in the EPROM. Press and hold the Economy button and the Up and Down arrows for 5 seconds. Get ready to tell an assistant the codes as they pop up. You may have to do this a few times to get them all. Repost the error codes here on Fixya if you don''t have an owners manual to interpret the codes.
Feb 25, 2011 | Heating & Cooling
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Jul 27, 2010 | Panasonic Heating & Cooling
My tank says I have 32 gallons left but the heater won't work (rinnai 556f). It turns on for about 15 seconds and the light on the power button turns red and starts blinking. What does this mean?
If you hold down the economy button and the up and down arrow buttons for 5 seconds the unit will start an error code display. Get a helper and yell out the numbers when they start blinking. Post the error codes and we can help you
Dec 23, 2009 | Rinnai EnergySaver 556 Air Conditioner
Rinnai EnergySaver 556 Air Conditioner Logo
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
