Question about Vehicle Parts & Accessories
1999 honda prelude why is a little red light appearing under my speedomiter
As I was driving home tonight I had a little red light appear under my speedometer, I've looked a lot of places. I think it might be for my oil but I'm not entirely sure.
    Top Expert:
  • 50,514 Answers
Check the mileage and if it is close to 60.000miles or100.000 klms I suspect it may be a warning light telling you that the timing belt is due for a change.
Posted on Jul 15, 2013
  • megan Jul 15, 2013
    I have high mileage. I'm at almost 234,000. But when I bought the car I had a mechanic look at everything so that I wasn't buying a piece of poo. Said it would last me another few months. I understand wear and tear. It's normal. Just can't figure out what it is. And how expensive it's gonna be cause I'm in the process of moving
  • Bill Boyd Jul 16, 2013
    At 234.000 I would think that the belt is due for replacement again. Talk with you mechanic and go on his advice. Be cautios on this because if it is a belt time indicator then by ignoring it you will be looking at big dollars.
1999 HONDA PRELUDE OVERHEATING
Verify fan operation(be carefull not to let the car overheat) and if they dont work try these steps. (If you have electeical know how)
check all fuses
check relays by swapping with another known good relay.
look around with a tester and see where along the circuit you are getting voltage.
replace the
6b70f36d-a432-4040-a5d9-7d3d751d5c8d.jpeg SpoonerTuner com Free downloadable Honda Acura Factory Service Manuals...
Jun 03, 2013 | 1999 Honda Prelude
I have an 89 honda prelude when engine warms up a blinking warning light appears. It is the same light that appears when my speedometer stops working. Can you tell me what it is trying to tell me? thank...
It sounds tempature related I would check the engine coolant tempature sensor Its going to be near the upper radiator hose where it attaches to the engine block a false reading from this sensor could screw up other systems abiblty to give correct readings to the vehicle control system and cause a lot of unasual unrelated problems to acure If you can i would seggest that you take it to an auto parts store most will read the codes for free although you have what is called an OBD 1 SYSTEM on board dianostic system OBD 11 is the newer system its likely a sensor and you will likely be able to fix it for under 50 dollars mabey 20 Good luck with it
Mar 05, 2011 | 1989 Honda Prelude
Please help!! My 1999 honda prelude is not running well. I regularly change the oil, and only use premium fuel. My car has about 160K miles on it. It sometimes starts, but when it does it spudders and...
Is it getting too much gas? check plugs sooty and black means too much fuel check light could be oxy sensor perhaps heater not working. This will cause fuel air mixture problems hope this helps mileage quite high but should be OK for Honda.
Jan 21, 2010 | 1999 Honda Prelude
Honda Prelude 1992, doesn' start!
Sounds like a crank postion sensor. Is this only when the car is hot/reached operating temperature
Aug 07, 2009 | 1992 Honda Prelude
1989 honda prelude diagnostic link location
Open your hood, it is located on the passenger side corner up against the fire wall. It is yellow pull the cap off bend a papper clip in a u shap. put it in turn key on but dont start car. there is a little flap in your captet on the passenger floor. the little red light will flash long and short blinks. then convert the code
Apr 26, 2009 | 1990 Honda Prelude
Where is the Egr Valve on the 1999 Honda Prelude--could I change
its in the engine intake and is a peice of **** to change..handy little job
Nov 29, 2008 | 1999 Honda Prelude
ABS LIGHT STAYS ON
possibly the pump has packed up.if you still have brakes and they appear to work ok evan without power assistance then remove the bulb and hope its not picked up on the annual mechanical inspection when they do a brake test,other than that it will be fine and should save you being the golden egg layer.
Nov 18, 2008 | 1996 Honda Prelude
Vehicle Parts & Accessories Logo
249 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
