The proline laptop always made the beep sound and switches itself off, now its totally off and when i switch it on, it switches itself off after few minutes of beeping.
No results found for "The proline laptop always made the beep sound and switches itself off, now its totally off and when i switch it on, it switches itself off after few minutes of beeping
hughv
  • 196 Answers
SOURCE: cannot swith on
Beep codes are specific to the BIOS, but this seems to indicate a bad video card, which needs to be replaced.
See here for more codes:
http://www.pchell.com/hardware/beepcodes.shtml
Posted on Oct 11, 2007
  • 102 Answers
SOURCE: ibm laptop problem
The beeps are telling you something is not right.
Every beep is different and I'm not 100% on what means what.
Most likely something is not inserted right into the motherboard.
Go back and check you inserted the ram correctly, if that dosn't work try checking your cables (ide, power, etc.) and your cards (video, sound, etc.) as they might have slipped out of place when inserting the ram.
You might even have a bad/faulty part in the motherboard. Check the new ram stick and see if it works without it.
These basic troubleshooting steps should help you find the problem. If not it could be the cpu is burnt out.....the way to know this is if you unplug it, the beeps will disapeir or change completely.
Maby someone else on FixYa could tell you what the exact beep could be but I'm pretty sure its just something not plugged in right or a faulty part like I had just mentioned. Either way your computer should work fine once the problem is traced and fixed.
Posted on Dec 27, 2007
  • 107 Answers
SOURCE: Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Posted on Jan 25, 2009
SOURCE: one long beep, two shorter beeps - HP laptop will not start up
Hi...
I had the same problem...
The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off.
Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Posted on Apr 13, 2009
  • 736 Answers
SOURCE: tha laptop just beeps when switched on. power ok,
4 short beeps might mean you have a bad memory module (beeps are coded) .. if you have two memories installed you can try takeing one out at a time .. it will start working when the good module is the only one plugged in .. just removing and replacing the memory sometimes cleans the pins so that it works again .. ... there are other possibilities that are more expensive usually ... so you hope its just the memory .. here is a site that gives beep codes for many machines ..
http://kb.iu.edu/data/afzy.html
Posted on Oct 06, 2009
Proline microwave 3535T sound not working
Your question is not really quite clear. What kind of sound is supposed to produce a microwave oven?
It works or not? Heats or not?
If it won'r work take it to repair to s qualified microvawe repair tech.
Jun 18, 2015 | Microwave Ovens
My jbl micro speaker keeps switching on and beeping can it be fixed
It sounds like you have a defective on/off switch. Read through the documentation about resetting the device. You might also try blowing some canned air over the switch while pressing and unpressing the switch. There could be some large particles lodged in the switch.
The first point of mechanical failure is the on/off switch and given the way these smaller speakers are manufactured there is little hope of repairing the switch itself.
Feb 27, 2015 | JBL Audio Players & Recorders
How can i stop my(other) proline pc from shuting itself down while i am repairing harddrive
First it most be plugged into a wall outlet or it will go to sleep to save the battery. Next go into control panel, Power setting & tell it to never go to sleep. Then reset this when you have finished your HD repair.
Dec 03, 2014 | Microsoft Computers & Internet
Repair a proline W763s LAPTOP when replacing hard drive
It has lost any operating system.
You need to put an operating system on the new drive, before putting in the laptop.
Sep 27, 2014 | Computers & Internet
My Proline W76S laptop switches itself off after few seconds and does not want to re-boot, i took out the battery and tried with the internal power source but still th same problem, i tried ctrl+Alt+F
It sounds like your CPU could be overheating. Verify that there is no dust blocking the exhaust fans. If there is, use some electronics air cleaner to remove it and try again.
Mar 17, 2013 | Computers & Internet
How do you switch on a webcam on proline laptop
Try typing proline laptop into Search when you log into YouTube. Jimmy
Apr 10, 2012 | Computers & Internet
My IBM T41 make beep sound and turns off itself. What is happening?
You can try the steps below.
Try removing the battery and plugin the charger and try turning on.
Do you see any thing displayed on your screen when you switch on?
Please mention the beep pattern, 2 beeps or continuous beep.
Hope this helps. Good Luck
~SmokinJoe~
Aug 24, 2011 | IBM ThinkPad T41 Notebook
Laptop problem
1 long beep + 2 short beeps during a POST (Power-On Self Test) for a IBM ThinkPad stands for System board, video adapter or LCD assembly failure.
Dec 27, 2007 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
