Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Vertical line on KDL-32s20l1
I see a thin pink vertical line on bright backgrounds, but on dark backgrounds the line is gone and the picure is great. This trouble is on any picture mode.
    Problem Solver:
  • 11 Answers
Sounds like the screen is faulty from my experience of LCD,Sorry
Posted on Nov 04, 2007
    Scholar:
  • 53 Answers
You'll get this abnormality some times due to the signal if you're watching regular analog picture and you have your TV set on full screen, the TV will stretch the picture and you will see more defects than if you're watching it on normal picture. But if you are seeing the same problem when watching HD picture it needs to be serviced try this link I found: http://www.moniserv.com/doc/lcdtv.html
Posted on Aug 28, 2007
SOURCE:
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
7inch vertical color lines right side of screen all th time
Hi.
This website has the service manual ($7.79) with instructions to diagnose the boards. Unfortunately I am afraid that the problem is not a board but the panel itself.
Thin vertical lines in the middle of the picture mean that the panel is gone. Here an example of lines from bad panel in Toshiba LCD:Line Picture. (discussion: Avsforum). Sometimes the lines can be dark or in bright color.
The panel costs $339 (LCD PANEL ASSY).
Because of the price of the panel, the TV is not worth repairing unless under warranty.
Even if the TV is out of warranty call Toshiba and report the problem. As you can see in AVSforum page above the problem is affecting many users.
If Toshiba doesn't offer special conditions on repair (or discount on new), the TV is not worth repairing. Replacement of the digital board will hardly be a solution.
Only if you have wide bands, scrambled or flickering, then the problem is digital board (main board) or panel.If you have the thin pixel lines, then the panel is gone.
Dec 10, 2011 | Toshiba 40RF350U 40 in. LCD TV
TV has power but picure doesnt come on - flashes 'please wait'
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Thanks
Oct 01, 2009 | Televison & Video
LCD Displaying Red instead of Black, Vertical Lines in Display
I had a similar problem where the screen went to a pink shade periodically. Sony sent me a memory stick, with download instructions, that fit into one of the back ports. The problem has gone away. It was a software correction.
Mar 15, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
485 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
