Question about Sharp LC Televison & Video
Out put voltage is low - LC Sharp Televison & Video
    Top Expert:
  • Sharp Master
  • 74,136 Answers
Check and change its main power regulator board.
Posted on Jul 15, 2013
Both headlights dim 2002 mercury sable
Get a load test on both. There are 2 components to checking the system voltage and amperage. You can have good voltage but low amperage which will cause issues. 12.75v is low. A battery fully charged should be closer to 13.8v and charging should be around 14.4v
Oct 28, 2016 | 2002 Mercury Sable
Hyundai santa fe 2001
Car error codes::
Diagnostic Trouble Code Storage Condition Remedy
P0100 Mass Air Flow Sensor Voltage High C-8
P0100 Mass Air Flow Sensor Voltage Low C-8
P0110 Intake Air Temperature Voltage High C-10
P0110 Intake Air Temperature Voltage Low C-10
P0115 Coolant Temperature Voltage High C-9
P0115 Coolant Temperature Voltage Low C-9
P0120 Throttle Position Sensor (TPS) Voltage High C-7
P0120 Throttle Position Sensor (TPS) Voltage Low C-7
P0130 O2 Sensor 1 Circuit Voltage High C-30
P0130 O2 Sensor 1 Circuit Voltage Low C-30
P0130 O2 Sensor 1 Open Circuit C-30
P0150 O2 Sensor 2 Circuit Voltage High C-31
P0150 O2 Sensor 2 Circuit Voltage Low C-31
P0150 O2 Sensor 2 Open Circuit C-31
P0201 Injector Valve 1 Voltage High C-20
P0201 Injector Valve 1 Voltage Low C-20
P0201 Injector Valve 1 Open Circuit C-20
P0202 Injector Valve 2 Voltage High C-21
P0202 Injector Valve 2 Voltage Low C-21
P0202 Injector Valve 2 Open Circuit C-21
P0203 Injector Valve 3 Voltage High C-22
P0203 Injector Valve 3 Voltage Low C-22
P0203 Injector Valve 3 Open Circuit C-22
P0204 Injector Valve 4 Voltage High C-23
P0204 Injector Valve 4 Voltage Low C-23
P0204 Injector Valve 4 Open Circuit C-23
P0205 Injector Valve 5 Voltage High C-24
P0205 Injector Valve 5 Voltage Low C-24
P0205 Injector Valve 5 Open Circuit C-24
P0206 Injector Valve 6 Voltage High C-25
P0206 Injector Valve 6 Voltage Low C-25
P0206 Injector Valve 6 Open Circuit C-25
P0230 Fuel Pump Relay Voltage High C-6
P0230 Fuel Pump Relay Voltage Low C-6
P0230 Fuel Pump Relay Open Circuit C-6
P0325 Knock Signal Circuit 1 C-26
P0330 Knock Signal Circuit 2 C-26
P0335 No Engine RPM Signal C-32
P0335 Incorrect RPM Signal C-32
P0340 Hall Sensor Voltage High C-15
P0340 Hall Sensor Voltage Low C-15
P0403 EGR Valve Voltage High C-28
P0403 EGR Valve Voltage Low C-28
P0403 EGR Valve Open Circuit C-28
P0410 Secondary Air Pump Voltage High C-27
P0410 Secondary Air Pump Voltage Low C-27
P0443 Fuel Tank Ventilation Valve Voltage High C-29
P0443 Fuel Tank Ventilation Valve Voltage Low C-29
P0443 Fuel Tank Ventilation Open Circuit C-29
P0500 Vehicle Speed Signal C-42
P0505 Idle Air Control Voltage High C-33
P0505 Idle Air Control Voltage Low C-33
P0550 Power Steering Voltage High C-14
P0550 Power Steering Voltage Low C-14
P0560 Battery Voltage High C-4
P0560 Battery Voltage Low C-4
P0602 Control Module Programming Error C-2
P1110 Intake Manifold Valve 1 Voltage High C-34
P1110 Intake Manifold Valve 1 Voltage Low C-34
P1111 Intake Manifold Valve 2 Voltage High C-35
P1111 Intake Manifold Valve 2 Voltage Low C-35
P1230 Power Supply Relay Secondary Circuit C-3
P1405 EGR Valve Feedb. Voltage High C-28
P1405 EGR Valve Feedb. Voltage Low C-28
P1405 EGR Valve Feedb. Incorrect Signal C-28
P1501 Immobiliser No or Wrong Coding C-5
P1502 Immobiliser No Signal C-5
P1503 Immobiliser Wrong Signal C-5
P1530 A/C Relay Voltage High C-41
P1530 A/C Relay Voltage Low C-41
P1600 Reprogram or Replace Electronic Control Unit (ECU) C-2
P1602 Knock Control Module; Replace ECU C-2
P1690 Check Light Voltage High C-43
P1690 Check Light Voltage Low C-43
P1690 Check Light Open Circuit C-43
P1740 Torque Control Voltage Low C-40
P1740 Continuous Torque Control C-40
These are the error codes:
Jul 08, 2008 | 2001 Hyundai Santa Fe
Tip
My lights dim in my car, is this bad and what can I do to stop this from...
Lights dimming in your car is an indicator of a low voltage problem. This can be caused many problems. You might want to have your system checked out to make sure it is running smoothly. Low voltage can be a serious problem. Low voltage will cause an amplifier to put out a DC voltage rather that AC, which can damage your speakers. Low voltage can also cause damage to an amplifier by not providing enough power to the amp to run properly. You can add batteries and/or capacitors to the system to help with voltage problems. Please consult with a professional to make sure you get what you need for your specific setup.
on May 12, 2010 | Car Audio & Video
Low voltage
You have overloaded the generator and have blown a capacitor, resistor or similar item that will only allow half the voltage output to the recepticals. I know I have done this too.
Dec 05, 2013 | McCulloch 11 HP 5700 WATT GENERATOR
95 montero transmission shift problems + overheating + battery not charging
The first step is to see if the gauge are correct,low voltage can cause many problems, the first step is to make sure the coolant is full so check radiator, this is done when cold, if full then start the engine with a meter on the battery and watch the voltage, have someone put it into drive while holding brake. if voltage on meter starts to drop then give a little gas to rev engine and see if voltage goes up, if it does then you may have to low an idle but if the idle is ok then alternator is bad. also have the battery tested to make sure its good, just because it starts the truck does not mean its good. the next thing is to look at the overheating problem. if the cooling system is full and it runs hot then that must be looked at,when the truck is starting to overheat we assume it is due to gauge, but this sounds like it may be low coolant or low voltage or idle is to low because when you put it in park it drops. start with these checks and let me know the results. good day.
Feb 19, 2012 | Cars & Trucks
Good heat pump. I put a t-stat and the unit came on. took it off and put it back on the unit would not say a thing. What do you think the problem is.
You should check the low voltage fuse on the control board. check power to unit and check to see if you have low voltage.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
Check gages light is on what does it mean?
could be low fuel , low coolant temp , high coolant temp , low oil pressure , low voltage , high voltage , have a mechanic put a scanner on it make sure all is normal , might have false warning
Feb 17, 2009 | 2003 Pontiac Bonneville
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
