Question about Konka KDL32AT23U 32 in. LCD Television
Black sreen The sound is always fine and the picture will be fine to but then it will start flashing and we will loose picture, can sometimes fix by jiggling around but would like a long term solution. please help
    Top Expert:
  • Konka Master
  • 75,581 Answers
Check and replace its CCFL back-light lamps and back-light inverter board.
Posted on Jul 15, 2013
2005 Ford Focus is dead until I wiggle the battery wires
A ground wire that is not grounding, until you wiggle the wires. Follow those wires, there is a loose connection in there. Start at the neg. battery post, clean and tighten. Follow the small wires you can wiggle, see any splices that may have started to pull apart? Find the ground screw or whatever the small wires use to ground, that may be loose. Maybe the small wire goes to that black box? Take it off and look for the ground that isn't grounding.
Aug 16, 2013 | Ford Cars & Trucks
NO Picture
unplug for twenty minutes
Apr 18, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
2005 Focus has clicking noise under the hood won't start unless I jiggle the neg. battery wires
clean the negative terminal the do it up tight
the clicking noise will be that the starter solenoid is not getting a good current flow because of the loose terminal
Apr 02, 2017 | Ford Focus Cars & Trucks
My 31GT740 tv's picture is taking up to 5 minutes to come on...
There is possibly a loose solder joint in the horizontal drive circuit. There is a little coupling coil just before the horizontal output that will get loose. This should not be real expensive to have repaired.
Oct 20, 2009 | GE 31GT740 31" TV
No picture, can't set inputs on TV
try tighting the screws on the inverter. they sometimes get loose and then you lose the grounding.
Apr 20, 2009 | Televison & Video
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
Konka KDL32AT23U 32 in. LCD Television Logo
Top Konka Televison & Video Experts
Arnel
Arnel
matt martin
matt martin
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
