Every night at 2 am my PS3 signs me out of PSN. I still have internet on my laptop and every other device I have. My Netflix is on my PS3 and it is very annoying that I cannot watch it.
Unplug your router for about five minutes and turn off your PS3 and unplugg it for about five minutes as well. Sometimes its a cache problem.
If this does not work try setting up your DNS address manually on your PS3 under Network settings.
Change your primary DNS code to 129.250.35.250 and your secondary one to 129.250.35.251
Hope this helps!
SOURCE: On signing in to psn i get the error 80711008
Go to your Internet Connection Settings, then Disable the Media Server thing and it should work, hopefully. I did it and I think it's working now, because I'm downloading the new 2.76 Update.
SOURCE: connecting m y ps3 to my cradlepoint router ctr350 get online
i have a router a cradlepoint and i have my sprint aircard plugged into it and my ps3 says i cant connect but then i go to the web browser and it comes up my browser is to old and i hit ok then i just log into my cradle point and then i can log into my psn account
SOURCE: My ps3 internet doesn't work
Easy Pie! This is a cinch anda guarantee work through. It involves putting your PS3 into a DMZ (demilitarized zone) which simply means opening all of the ports on it.
If you have the following problems, this is likely to fix it.
Part 1-(On PS3)
Part 2-(On PC)
Courtesy of http://www.cod4forums.com/index.php?showtopic=3460
SOURCE: 80028E02 (this error keeps coming
ps3 error 80028e02 can be caused by different source of networkblockages. If you happened to be in a filtered network, that's your most probable reason why your ps3 is unable to connect online. For example, if you're in a school campus, there's a high chance that the IT network administrator has placed some restrictions to prevent hackers and other malicious online activities. You can refer to the campus IT department to find out if you need to access their local page for some clearance in order for your ps3 to connect online. If you have your own internet connection, the next probable cause is a router. Placing restrictions on some IP address or net services may have accidentally include your ps3 in it. You can change some settings within the router to grant your ps3 full access online, while at the same time maintaining other restrictions that are already in place. Another possible remedy is have your pc internet connection shared, and use your ps3 to use that shared connection to go online. These solutions are sure fire methods of keeping ps3 80028e02 away from your console.
SOURCE: Hi. I am trying to
Goto settings date and time and tell ps3 you are on daylight savings time. Then delete Netflix and reinstall.
