Question about Dell Latitude E5420 Laptop Computer
Boot Dell latitude laptop e5420 series. machine output is as follows, pxe-e61: media test failure, check cable. pxe-m0f: exiting broadcom pxe rom. no boot device found. press any key to reboot the machine. when i press any key to reboot i get the same prompt as above. what does this cable i'm being asked to check look like>?
ajx13
  • 110 Answers
SOURCE: my mini dell inspiration laptop sends me an error
This error comes up if the computer is not able to detect the hard drive. Power off the computer. Power it back on and tap the number 2 key 4 - 5 times at the Dell logo screen. This will take you to the system setp screen. Check if you see any thing listed next to solid state drive. If you dont see any thing try reseating the hard drive. Here are the steps to reseat the hard drive.. If you see an entry next to the solid state drive. You'll need to reinstall windows on the computer. If you have been shipped XP you will need an external CD drive to reinstall windows. If the system was sen with ubantu try to download it to a usb drive and boot off it.
Rate if useful.
Posted on Aug 08, 2009
  • 5 Answers
SOURCE: Problems with my inspiron 1501 details below
The problem your having could be the operating system is damange or the hard drive failed. Try to boot from a Windows XP or Vista CD to see if the drive is recognized.
Regards,
Posted on Sep 01, 2009
asingh1225
  • 122 Answers
SOURCE: PXE-E61:MEDIA TEST FAILURE PXE-M0F:EXITING BROADCOME PXE
hello, sounds like bad hard drive. here is what you can try, go in to BIOS and reset it factory default save and exit, let the system start again go back in BIOS and check to see if you see your hard drive there, also this time disable Boot from Network option. seeif your system actually starts up... or you get "no operating system found", if you saw the HDD in BIOS and get no operating system found, you can try reinstalling windows.
if you still media test failure and it loops, you need a new hard drive.
let me know if it helps...
good luck
Amar Sondhi
Posted on Dec 03, 2009
MSG-CPC
  • 1325 Answers
SOURCE: I have Dell latitude E5420.
hi
make sure your operating system is updated thoroughly (go to START, WINDOWS UPDATE)
once you have done this go to this link below, download the AUDIO drivers & BIOS driver
once this has been done, go back to the link and download all applicable drivers dated for 2010 or 2011. Once you go through all these drivers, it should resolve UNKNOWN device issue.
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cabsdt1&l=en&s=bsd&ServiceTag=&SystemID=LAT_E5420&os=WLH&osl=en&catid=&impid=
download and save all drivers, then execute them one at a time.
hope this helps you ! if so , please send me 4 thumbs up
Posted on Aug 01, 2011
bronk50
  • 27725 Answers
SOURCE: The sound is not working on my Dell Latitude E5420
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options playback recording sounds and communication select playback devices make sure it has a green tick have a look through all of these make sure all are configured properly
and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers
could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough
also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
if this fails to fix the problem take it back to the place of purchase if possible or ring them for some warranty advice
it might be a faulty sound card
it should be under warranty
hope it helps
Posted on Jul 14, 2012
First ther was a error message, then the pc make nothing.
If you have a spike in the power, unplug, remove the battery, then hold the power button down for 1min or 60s, to release any built up shock power. then insert the battery, (no power cord) push and hold power button for 1 -2 - 3 s. release and see what happens.. now what OS is installed on the HDD. and check the BIOS to see how the boot sequence is set... seems your error show you set to boot to NetWork not HDD
May 28, 2014 | Acer Aspire 5500 5570-2609 Laptop
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
When I turn my laptop on a black screen appears with: PXE-E61: Media test faliure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I do this and...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. Please click on this link and follow my instructions :- http://www.fixya.com/support/r4377704-pxe_e61_error
May 29, 2010 | Acer Aspire 5720-6661 Notebook PC
Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Mar 31, 2010 | Lenovo 3000 G530 Notebook
Boot error PXE-E61: media test failure, check cable followed by, PXE-M0F: existing Broadcom PXE ROM followed by, Operating System not found
Hard drive has been coruppted. Hold alt f10 on statup to format and reinstall. If that dont work you may need to try install from cd's provided when you purchased laptop. If that dont work buy new hard drive and restore from cd's. Good Luck.
Nov 23, 2009 | Acer TravelMate 800LCi Notebook
Video card failure replace your video card
Feb 10, 2009 | Lenovo ThinkPad T41 Notebook
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Dell Latitude E5420 Laptop Computer Logo
18 people viewed this question
Alun Cox
