Kf 55e200a My Sony tv flashes ared light three times and won't turn on we thought it was the lamp and replaced it but it still won't work what do we do?
    Champion:
  • 247 Answers
If its a dlp check the light engine there is a color wheel inside it may be worn out hence stuck and needs replacement do check that the fans are all working if one is not replce it to cos these r the only moving parts
Posted on Jul 18, 2013
4 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Sony KF-55E200A Projection TV turns on with sound
Replace Ballast board it is what powers Lamp on.
Encompass Parts 1-800-638-3328
Posted on Feb 14, 2011
jdvillanueva
  • 2098 Answers
SOURCE: My sOny tv KF-42WE610.. Won't turn on.. I just
Please let me know how many times it will blink to determine where the exact fault came from.
Jdvillanueva
Posted on Jun 17, 2011
SD Tech
  • 14553 Answers
SOURCE: tv sony KF-series 5000463 we42A1 lights broken image on the tv monitor does not appear part sony lights are hard to come by in Jakarta on Singapore's existing dealer sony lamp
If looking for replacement lamp unit GOOGLE the model number and "lamp" to locate a seller who will ship there for you.
Posted on Apr 11, 2012
Ihave sony bravia kf 55e200a tv, but my tv wont turn on. The red light flashed 4 times and display flashed and off how can i fix.it
it is caused by a shortage in circuit board. it can be fixed by check and replace faulty components in main board.
if it is in warranty then claim it now,
if not then take it to a service shop.
Aug 02, 2015 | Sony Televison & Video
Sony bravia kf-55e200a
Should be lamp door not properly closed--a lot of these the heat from the lamp warps the door.
Door has a plastic peg on rear that will with the door closed engage a lever behind it(safety switch which prevents set from being operated with door removed).
To know you remove the door, engage the lever with something not metal(match stick or Q-tip and hold lever to the rear of set direction)
Plug set in with that done and turn on-----if it comes on DO NOT LOOK DIRECTLY AT THE LIGHT FROM THAT LAMP.
iF IT COMES ON YOU NOW HAVE A WORKING SET AND NEED TO REPLACE THE LAMP DOOR ITSELF.
IF ANY QUESTIONS LET ME KNOW.
happy holidays
Dec 22, 2012 | Televison & Video
My sony KF 55E200A projection tv is loosing its colors what can be done to cure it ...plz help.
I need to know if areas of the screen are green or blue with the color set to zero or with the set on a unused video input with nothing connected is the screen a uniform grey or black? This will point to what kind of trouble you have.
Dec 12, 2012 | Sony KF-55E200A TV Lamp with Housing
Jdvillanueva
Jun 17, 2011 | Sony Televison & Video
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a Sony kf-50we620, It started having problems this week. Sometimes, not always, I turn it on, the green light flashes and the TV will eventually start but it takes over 2 minutes to start. I will...
Its symptoms of weak lamp that need to be replaced.
How old is this TV and did you replaced its lamp recently?
lamp replacement is easy and would be written in user manual. Please buy Sony original lamp for TV safety.
Thanks.
Jan 15, 2010 | Sony Grand WEGA KF-50WE620 Television
Sony KF-60WE610, green light flashes few times and return to red, what could be the problem TV only five years old
Your lamp (back lighting) is burnt out and need replacement. The instructions are in your manual
Nov 08, 2009 | Sony XL-2100U Projector Lamp for...
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony kf-50XBR800 tv turns itself on and off
I just purchased a replacement lamp off ebay and the TV is working fine now. Color looks better too (which I guess I should have expected). Search for "REPLACEMENT LAMP SONY XL-2100U" on eBay and look for seller "niosales". I paid $129 out the door. Their are other auctions for this lamp you can check out. Make sure you look at lamps that include the entire lamp housing, not just the bulb.
Jan 24, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
