Question about Samsung Sgh I927 Captivate Glide - 8gb - Black at&t Smartphone
Yellow triangle with exclamation mark next to the battery symbol
5 Suggested Answers
  • 11 Answers
SOURCE: light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
Posted on Aug 17, 2009
  • 491 Answers
SOURCE: symbol with exclamation mark in a triangle keeps
How often does it appear?
Is it after the TV has been on for at least 10 mins?
It could be overheating.
Add a fan to get air flow into the set through a vent in the back....and see if that helps to keep the light off.
If this cures it....the internal cooling fan may have stopped.
Posted on Sep 06, 2009
digitalcopie
  • 77 Answers
SOURCE: Constant red light on the exclamation mark inside
change toner.
Posted on Oct 11, 2009
milkburp
  • 416 Answers
SOURCE: replaced bulb now shows only triangle with
Check your lamp door. If it looks good, remove it. Now, push the lamp door up. Reach around the TV with the remote and try to turn it on. If it comes on, your lamp door wasn't on right. If it doesn't, you may have something going on below the lamp. It the lamp exploded, the hot glass fell out of the lamp and went down into the cooling fan below. It may be stopping it from turning. I hope this helps, best wishes.
Posted on Apr 29, 2010
What does a yellow exclamation point inside a triangle warning sign mean. Now check engine light just came on.
The yellow triangle with an exclamation mark will typically be accompanied by a message explaining what's gone wrong. Hopefully it will be self-explanatory - such as a low reservoir for the windscreen washer system.
Dec 28, 2017 | Cars & Trucks
Turn on tablet and get a black screen with a battery symbol and a yellow triangle with an exclamation mark. What is wrong? This happened after charging
i>>There is problem in battery of your Android Tablet.
>> First you need to check your device battery, and if it is faulty then replace it from Service Center.
>> To save your Battery Life Please follow these solutions:
>> Remove Unwanted Application
>> Turn Off Data Connection when not in use.
>> Close Application that are not in use currently.
>> Also remove live Wallpaper and Set image as wallpaper
>> And Use genuine Charger for your Tablet
>> That's it.
All the Best
Oct 29, 2014 | RCA DAA730R - New 7" Android Tablet w/ATSC...
I have an 08 Trailblazer and the yellow ! in a circle is on... a symbol of like tire marks with a wrench next to it and the tire marks in a triangle.... what does all that mean?
I guess you have no owners manual !!
Tire Pressure Monitor Symbol
Go to a tire store-- they will explain it to you
& resolve any issues there
Mar 05, 2013 | 2008 Chevrolet Trailblazer
Wi-fi is connected but wont open web page
If you see an exclamation mark in a yellow triangle over the WiFi icon next to the date you are connected on a local network only mastericpr08.png Like this
Nov 09, 2010 | HP Compaq nx9500 Notebook
I have a yellow triangle with an exclamation mark
ESP = Electronic Stability Program malfunction indicator lamp (MIL)
1. You can try to disconnect the battery from car terminals, waiting for 30 minutes and connect again the cables in order to reset the ESP Electronic Control Unit (ECU).
2. If this procedure does not work you must use a diagnostic equipment connected to the Data Link Connector (DLC) of the car. The ESP ECU fault memory can only be accessed and erased using diagnostic equipment connected to the DLC.
Note: ESP function includes ABS (Antilock Braking System) function!
Mar 31, 2010 | 2002 Audi A4
The symbol is a yellow exclamation mark inside a
It is the Tire Pressure Mounted System (TPMS). It monitors the air pressure in your tires. If it is on, you have low tire pressure...or like me, it's just a faulty indicator. Mine came on, but I don't even have TPMS on my vehicle.
Aug 26, 2009 | 2004 Dodge Durango
Warning symbol on mini cooper
If it is yellow and looks like a tire it is the flat tire light, and you should check his tire pressure. if it is a yellow triangle with an arrow going around the triangle with a exclamation point in the middle this is your DSC or ASC and if it is on all the time these features are inactive and you should hit the DSC/ASC toggle switch to the right of the drivers window switch. If this symbol just flashes briefly this means the DSC/ASC is presently activating. thest are the tow that I can think of, I hope this helps.
Dec 04, 2008 | 2005 Mini Cooper
Hp desktop 1320 printer has yellow light on - it the icon symbol
The symbol for toner low is a box, without a top, with an arrow made of dots pointing up. Insert an new print cartriage.
Nov 12, 2008 | HP LaserJet 1320 Printer
Samsung Sgh I927 Captivate Glide - 8gb - Black at&t Smartphone Logo
102 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
