Question about Fuji FinePix F470 Digital Camera
Screen in toast!
When I turn on my Fuji Finepix F470 it shows a white screen with what looks like a large black spot and a crack in the LCD screen not the outer clear plastic screen. It then shuts itself off 2 seconds later. I can see the black spot even when it is totally off, maybe the LCD is leaking, I have no idea, someone help! Thanks.
    Problem Solver:
  • 16 Answers
That is definately a cracked lcd your describing! I doubt there is an easy solution but maybe... If you are able to get into the menu and disable the LCD that might help. However! The fact that the LCD is broken shouldn't keep the camera from running (though its remotely possible) If you can't shut it off or work without it the odds are you've got an expensive paperweight. At least thats what I gather based on your description.
Posted on Aug 27, 2007
There is a black spot on the digital screen. It does not show up in pictures but it is on the digital screen. Any fixes?
Unfortunately this is a permanent damage on the screen display - it needs to be replaced. The LCD glass has a cracked - the black spot is the crack. It should not effect your pictures when you take them.
Nov 12, 2010 | FUJIFILM FinePix Z70 Z71 Digital Camera
Fuji FinePix F470 works perfectly unless a memory card is present
Some cameras are very sensitive when it comes to memory cards for some odd reason. I would try a different make of sd card.
Oct 13, 2009 | Fuji FinePix F470 Digital Camera
Lcd screen has black spot inside, outside fine, takes pictures
you should replace the lcd screen from an authorized service center. or you can buy the lcd screen alone from ebay and find someone to replace it .remember
never open the camera unless you know very well how to replace it.thanks for using fixya. please dont forget to rate my solution
Jun 01, 2009 | Fuji FinePix J10 Digital Camera
Fujifilm camera f470 white lines problem horizontal
your shutter is not closing over the lens completely. try taking video, that should be ok. your lens will have to be stripped down to clean the shutter
Apr 02, 2009 | Fuji FinePix F470 Digital Camera
Problem with F470 Fine pix camera
sounds like the keypad ribbon has either popped out of it's socket or, and this would be the common fault, the ribbon has broken. In which case fuji will be your only way to fix and get it serviced at the same time. last quote I recieved was £80.
source a donor camera on ebay for the cheaper option
Jan 06, 2009 | Fuji FinePix F470 Digital Camera
I have a Fuji F470 digital camera. It was dropped. Now when I turn it on, the screen displays Finepix, then goes blank.  It seems to take pictures,,,lens moves in and out and flash works, but I can not see...
hi, when you drop it , it broke the color chips sensor , to make it repair , the coast it always arround 125.00 and + , so i sujest , your can try your waranty or buying brand new , ( ) they have good price yvon chow !!!
Jan 02, 2009 | Fuji FinePix F470 Digital Camera
White LCD Screen
This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. Please check the following two links for more info:
Applicable cameras include:
F303, F410, and F700
Dec 09, 2007 | Fuji FinePix F410 Digital Camera
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Nov 16, 2007 | Fuji FinePix F470 Digital Camera
Fuji f700
I recently had trouble with the LCD Display coming up with a black screen. So I mailed it to Fuji with a letter explaining the problem. About 3 weeks later I got it back in the mail and it seem to be working fine until a month later. I turned it on and the LCD display show a black screen only now it has white lines. I'm so incredible mad and extremely dissapointed in Fuji. Reading online I have notice many people having trouble with Fuji Products. I WILL NEVER BUY a Fuji again!!!
Jan 15, 2007 | Fuji FinePix F700 Digital Camera
Fuji FinePix F470 Digital Camera Logo
117 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
