Coonara gas model CGLI-20B serial 86061
Lost manual, may need new ignitor switch?
hemantraj
  • 638 Answers
SOURCE: My Caloric gas wall oven
yes definitely you could get this part.
Posted on Jun 11, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: Need a new ignitor for a gas double oven
hello, here is a link to order the part your looking for its a web sight that has the ignitor for your kenmore 911-3218811 it also shows a picture of the ignitor so you can compair it to the one your looking to replace.
http://www.repairclinic.com/Appliance-Parts?s=t-911-3218811+-%3d%3dc249
Posted on Mar 29, 2009
  • 582 Answers
SOURCE: Maytag gas dryer, model mdg9206bww, has lost
try checking the voltage commimg into the dryer outlet make sure you have 208/220/240 volts at the two hot terminals and 120 volts from ground to each of the hot terninals if only getting 120 to one terminal you have a bad breaker or fuse
Posted on Aug 23, 2009
  • 4736 Answers
SOURCE: can i use a universal remote on a gas heater
If the universal remote is compatible with a milllivolt gas control valve receiver or it comes with a millivolt receiver that can be wired into the heater, then it should work. If it doesn't do or have any of the aforementioned, then, no it probably won't work. The hand held remote and the receiver frequency have to match or be capable of being reprogrammed.
Hope this helped to answer your question.
Posted on Apr 22, 2011
SD Tech
  • 14553 Answers
SOURCE: i can't open a microwave model AMW-20B
The actual door or the top/side covers?
Posted on Dec 13, 2012
How do i get this to the heat setting ?
Hello there.
If you have the right model of this machine
Press 'mode' switch as per page 9 of user guide here
http://www.soleusair.com/Manuals/2014%20B%20manuals/SG-PAC-12E1%2012E1HP%20manual%2010052012.pdf
Also can do it on the 'remote control' if you have it.
Sep 16, 2014 | Soleus Heating & Cooling
How do I replace ignitor switch in thermos gas grill, if this is what is what I saw?
If that white is ceramic, I think it is the actual ignitor, not the switch.
Apr 29, 2017 | Thermos Stainless Steel Gas Grill
How do unlock my sentry electonic safe?
Hello, If you don't have the combination you will have to write sentry cust service with the model and serial number to get the combination. Here is their number you can call: (800) 828-1438
Jun 01, 2014 | Audiovox APS20B Prestige Programmable...
Heater shuts off and ILO shows on the screen
ILO stands for Ignition Lock Out.
This heater must be on a propane gas system as that is the only model that supports the ILO feature.
This either means that the gas supply is insufficient, or is turned off, OR...
the ignitor / flame rectifier have failed.
As long as you know that the pilot orifice is clean and free of debris, and the gas supply is turned on and correct, you simply need to purchase and install a new ignitor for this heater. I would normally list the part number and a place to buy it for you, but there was no model listed on this post.
On raypak heaters, the ignitor is actually the same part as the flame rectifier (flame sensor) .
What this means is that even if the ignitor portion is working, and your heater is igniting, the ILO code is telling us that the flame sensor is not sensing that it is lit. This is when it shuts down and gives the ILO code.
If you lost your manual and need a part number contact me @ : adamh@newconceptchem.com
I have most raypak ignitors in stock if you are interested.
Dec 07, 2010 | Raypak Pool & Spa
I need ignitors for heater model number 3e219e
The part number for the ignitor kit is PP200 (new number) Old number was PN HA 1000.
Also from the parts list, this PN: 102548-03
Parts list:
http://www.bealsmotor.com/105553_219E.html
Burner head parts: (Ignitor is item 5)
http://www.bealsmotor.com/105553_burner.html
Actual Ignitor Kit:
http://www.amazon.com/Desa-International-Hot-Surface-Ignitor/dp/B000DZDPVI $39.95 + shipping
Downloadable manual: http://www.desatech.com/manuals/Construction%20Heaters/105553-01.pdf
Dayton Portable
Oil-Fired Heaters
PARTS:
Ph. 1-800-323-0620
24 hrs / 365 days a year
105553
2E510F, 2E511F, 3E218E, 3E219E
Please provide following information:
-Model number
-Serial number (if any)
-Part description and number as shown in parts list
102548-03 (part you need)
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | Dayton Heating & Cooling
My kenmore oven igniter doesnt click and there is no gas getting to the oven
Oven ignitors are not the "clicking" variety - they use a hot surface ignitor and "feed through" to a current sensing gas valve - in short, if the ignitor is going bad, then the gas valve won't open (safety). Try replacing the HSI in the bottom of your oven - do an online search and match up model and serial of your unit to the part. Be careful no to touch or break the new ignitor - VERY FRAGILE!!!
Aug 31, 2009 | Kenmore Ovens
Gas Burner ignitor is not working
Yes it should be an easy fix.
Ignitors simply go bad from time to time.
If you have a meter you can check to see if you have voltage going to the ignitor. If you do, and it isnt trying to ignite, replace the ignitor.
If you have no meter, ignitors are usually less than 30 bucks so you will not be to much in the hole by just replacing it.
If you lift the cover to access the ignitor, it should be held in by two crews, the gas tube, and a wire to the flame sensor.
Make sure you turn off all gas and electric before disassembling.
You can find ignitors at your local appliance parts supply house.
All you need is the model and serial numbers.
Dec 27, 2008 | Cooktops
I have a problem with an Armstrong SX90 gas furnace. model GUK100D14-2B serial number 8497G26541 The ignitor is not 'glowing' and therefore the pilot won't light. Everything seems to be sequencing...
Buy a new ignitor either from the ignitor store online, or your local distributer, Contracter, dealer.. they usually run from 15 dollars to 35. Their simple to change out and deffinite do it yourselfer... Oh and turn off power at breaker panel, you don't need any unexpected surprises!!
Dec 02, 2008 | Heating & Cooling
Heating & Cooling Logo
200 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
