SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
SOURCE: E02
Click on Bosch (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
SOURCE: E02 error and heater will not start. Service
high limit is open this is due several factors like slow water .pump on low speed or dirty filter, also hard water, or assembly valve not working properly so make sure the filter is clean check the water chemistry an last check the valve assembly. make sure plumbing is correct water in and out from the heater
SOURCE: error code E02 on washing machine-3 beeps
you should buy a new one..
check this one..
http://www.washingmachineadvisor.com/
