Br629t video recorder
How can I find language connection numbers to remove sub titles when recording
  • 244 Answers
SOURCE: Nothing records when I do a scheduled recording
Doesn't record properly, ie: looks like one channel is down when recorded, pre-recorded tapes are ok
Check Q008 for dry joints
Posted on Nov 24, 2007
GSAN
  • 106 Answers
SOURCE: Recording from Sky+
could be possible that Sky TV is right protected therefore making it hard or impossible to record.
Posted on Jun 12, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: Can't record from tv
u have a cable/sateliite connection...cable from wall to cable box in...cable box out to vcr/dvd in....vcr/dvd out to samsung lcd in....(vcd/dvd and samsung must be tune to ch 3) now u should be able to record all channel (note HBO, and some others like it may not allow dvd recording) vhs yes.
if this helpful feel free to rate
Posted on Jun 16, 2009
SOURCE: Cannot record from my DirectTV DVR, HR20-700
most dvr units froim cable and satellite companies use a type of copy protection that does not allow you to copy programs to a disc. the cable company wont tell you this but they do and there isnt any way to work around it
Posted on Jul 18, 2009
SOURCE: Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
Posted on May 08, 2010
I can't figure how to get the closed captions to work. I am nearly deaf.
Press SETUP
Get to LANGUAGE SETUP PAGE
You can select OSD language, and select audio/subtitle/menu
language of DVD discs if available. Also you can select font type for mpeg4 subtitle
Remember you get SUB-TITLE only if your DVD supports it meaning contains it at the first place.
Sylvania SDVD9020 User Manual Setup Menu Setting
Feb 19, 2016 | Sylvania SDVD9000 Portable DVD Player
REMOVE SUB TITLES
Sub-titles are commonly available to be turned on/of or changed to various languages using either the equipment's menu tree, or the main menu setup,setting,options,etc. of the movie, game, or whatever you're viewing. If it's not easily found in a menu or video/viewing options (possibly audio) look for a button that is labeled 'SAP' and try that. good luck
Nov 16, 2013 | Zenith XBV443 DVD Player/VCR
How do I record information, shut the recorder off then go back to the same spot and continue recording information so that all the information is all together?
Most digital voice recorders, have a filing system. It is usaully labeled either: A, B, C, D or 1, 2, 3, 4 (these are the main folders) and each of these folders contains a set amount of files (in most cases about 99 subfolders). So you can have folder A file 1, 2, 3 and so on... When pressing the RECORD button for the first time you are in one of the main folders and your recording gets a sub folder number. To continue recording where you left off last time or where 'stopped' use the PAUSE and not the STOP function. The moment you press STOP instead of PAUSE you will change the sub folder number - and therefore not have one continous recording. If you turn the power off or remove the batteries you will also change the sub folder number. Most of the better recorders have a voice activation function that places the recorder on pause automatically when there are no sounds. It will not change the sub folder number when it starts recording again - and will automatically pick up where it left off.
Apr 24, 2011 | Olympus VN5200PC Voice Recorder
How can i remove unwanted subtitles the movie is in english and the sub titles ate very distracting
Usually, if the subtitles are from your dvd player, you can go to the main menu, select "languages" or "setup" (depending on the dvd), and find the subtitle option. You should be able to shut them off there in the menu. If the subtitles are there because of your tv, there should be a button labeled "cc" on your remote. If you press this key a few times, it should eventually read something like "cc off" on the tv screen. I hope this helps, and good luck! Sincerely, Der Strom
May 10, 2010 | LG DR-4912 DVD Recorder
Subtitles will not remove from t/v even when subtitle button is pushed on remote control
The sub titles are being generated by your Cable box or the Sat box. Sub titles are generated from two different sources: Cable Box,Satellite Box,U-Verse Box etc.
Check the settings in those sources and make suer the sub title is turned OFF in the tv set.
Apr 16, 2010 | Televison & Video
How to remove sub titles from Sagem Digibox in UK
Bottom row of buttons, second from the left (Picture of screen with a line at the bottom). Press that and the subtitles will come and go as you wish.
Jan 15, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
How do i change the language on my pioneer avic-d3 player
here is the link to your manual:
http://www.pioneer.co.uk/uk/support/manuals/AVIC-D3/index.html
Setting the language
You can set a desired subtitle, audio and menu
language. If the selected language is recorded on
the Disc, subtitles, audio and menu are displayed
in that language.
1 Touch “Language” and then touch
“Subtitle Language”, “Audio Language”
or “Menu Language”.
Each language menu is displayed and the currently
set language is selected.
2 Touch the desired language.
When you select “Others”, a language code
input display is shown. Input the four digit
code of the desired language then touch
Enter”.
➲ “Language Code Chart for DVD” ➞
Page 114
from the manual:
English (en), 0514
❒ If the selected language is not recorded on
the disc, the default language specified on
the disc is output and displayed.
❒ You can also switch the subtitle and audio
language by touching “S.Title” or “Audio
during playback.
➲ “Changing the subtitle language during
playback (Multi-subtitle)” ➞ Page 75
➲ Changing audio language during playback
(Multi-audio) ➞ Page 75
❒ Even if you use “S.Title” or “Audio” to
switch the subtitle or audio language, this
does not affect the settings here.
Setting assist subtitles on or off
Assist subtitles offer explanations for the aurally
impaired. However, they are only displayed if they
are recorded on the DVD.
You can turn assist subtitles on or off as desired.
1 Touch “Assist Subtitle”.
Touching “Assist Subtitle” switches
between “On” and “Off”.
Cheers!
Jan 11, 2010 | Pioneer AVIC-D3 Car DVD Player
Closed caption
Try setting your subtitle language to "OFF".
■ Selecting a subtitle language
Select your preferred subtitle language. (The disc must contain the selected language.)
You can also select another available subtitle language during playback with the
Subtitle button on the remote control during playback.
1 Press the Setup button, then press < or > button to select Preference Page.
2 Press ∧, ∨ buttons to select SUB TITLE.
3 Press the Enter button or > button and then press ∧, ∨ buttons to select
your desired language.
4 Press the Enter button.
5 Press the Setup button to resume normal playback.
Note: Supported subtitle languages are English, French, Spanish, Portuguese, German,
Italian, Russian, Chinese, Korean and Off.
Oct 18, 2008 | Akai LCT2721AD 27 in. LCD Television
Sub-title does not appear.
It's called "closed captioning" and should be under the menu/setup button. Subtitles are only for DVD players.
Jun 24, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
DVD Tracking problem
Contact Bose with the serial number from your media centre. they'll send you a software update disc free of charge which WILL solve this problem
Jan 15, 2008 | Bose 3·2·1 II System
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
