Question about Mtd Garden
Wanting a manual for mtd model no. 618-0073 serial no. A491409
We are looking at replacing a bearing on the spindle connected to the mower blade.
  • 257 Answers
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Posted on Aug 15, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
  • 760 Answers
SOURCE: Need manual for MTD YardMan riding mower serial
Go to :
http://manuals.mtdproducts.com/mtd/Public.do
Put in : 13AF675G062 I think that's a zero six two not an O six two.
Then your serial number. There are owners manual and parts manuals there.
Posted on Aug 05, 2010
  • 24 Answers
SOURCE: need a manual for a
If you go to the MTD website you can enter your model and serial number and you will be able to download your manual.
here's the link - http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Posted on Jul 18, 2011
SOURCE: replacing a MTD spindle assembly
Yes, most spindles come with non threaded holes. The metal is soft and you can just use regular bolts. Once you start them, they cut their own threads.
Posted on Jun 03, 2012
Testimonial: "Good, I was afraid I had the wrong part. Thanks for your help!"
When taking off the blade for replacement one side of the attachment assembly broke off. i can't figure which nuts/bolts to loosen to remove that part for replacement
The spindle assembly is usually held in place by bolts through the mower deck. The deck will need to be removed from the mower to get to them. There will be three or four of them at the base of the spindle assembly, remove these and the spindle will fall out the bottom
May 15, 2016 | Mtd Garden
MTD model number 13RL771H029. I purchased it in 2008 with 46" deck. Are all 3 spindles the same part number
I have an operator's manual for an MTD Model Series 760-770 Lawn Tractor. This Manual seems to indicate two different part numbers for the spindles on a 46" deck. One spindle is a Double Pulley, part number 618-04134B. The other two spindles are single pulley, part number 618-0240A.
However 760-770 is a series number. So this does not necessarily match your machine. The first question is what year is your Lawn Tractor? Following is a discussion of MTD serial numbers from 1997 till now. Pre 1997 is a different discussion.
The second question is what is your actual Model Number?
Locating Your Model and Serial Numbers
The model and serial numbers are essential to find correct MTDĀ® genuine factory replacement part numbers for your outdoor power equipment. Once you know these numbers, you can use either the illustrated parts look-up tool or the operator's manual download to easily search for the correct part numbers needed.
What should my model and serial number look like?
MTD's current (1997 and later) model and serial numbers are generally 11 characters in length. A character could be a number, dash or a letter. If 0 represented all numbers and/or dashes and X represented all letters, the model and serial numbers should appear as follows: 00XX000X000.
These are made of both letters and numbers, and typically look like this: 11AA111A111.
Apr 11, 2015 | Garden
How to replace spindle bearings on woods l59 woods mower
well last time I looked their spindle assy's weren't rebuildable. since I cant remember I will say this, you have to remove the center bolt to explore further...
Sep 02, 2014 | Garden
Mtd engage blades it smokes and make noise
Have you physically moved each blade by hand (with the machine shut-off),spark plug disconnected to see if both or all of the cutting blades move freely if there is any binding you probably have a bad blade spindle bearing . If those move o.k. then you're going to want to check the pulleys on top of the deck, one of these which do not go to the blades may possibly have a bad bearing and is not moving freely causing the belt to be burning up.
Dec 03, 2012 | Garden
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
Replacing a MTD spindle assembly
Jun 02, 2012 | Mtd Garden
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Replace transmission belt on my 42" MTD Mower
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Jun 01, 2009 | Mtd FASTATTACH MANUAL SLEEVE HITCH
MTD blade spindle problem
yes match it up from the one off of your other spindle and or take the sample to a hardware store and find something close that would do the job for you
May 03, 2009 | Garden
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
