Altec Lansing ada745 5 piece system. What is the jack on the back of the sub labeled (diag out) for and what are some specs. Thanks Adman
5 Suggested Answers
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
nitantsoni
SOURCE: Altec Lansing ATP3 broken speaker wire ORANGE connector/jack.
Here you go
Posted on Aug 27, 2012
kjhbwtgbwr
you can find it here: Amazon com altec lansing power supply
(chargers from other altec lansing models are compatibile too)
take a look
Posted on Oct 14, 2014
Wiring diagram for altec lansing acs340 sub woofer
This is not something that you will get access to from here. Try asking a repair shop if they can get the schematics for this speaker. You could also contact A-L directly.
Not likely to happen.
Altec Lansing ACS340 Specs CNET
Furthermore these are inexpesive 2.1 speakers that can be replaced for 30-40 dollars. Not worth the effort.
Mar 09, 2015 | Altec Lansing Audio Players & Recorders
How do Altec Lansing AVS200W 2-Piece Multimedia Speaker System connect to your computer
Using a regular audio cable with 3.5 mm. connectors at both ends, connect your computer to the speaker from the the headphone jack to the 3.5 mm LINE IN jack on the speaker.
Jul 10, 2014 | Altec Lansing Avs200w 2-piece Multimedia...
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
Dell dimension 5150. Adding Altec Lansing acs410. Two speakers with a sub. Back of speaker has 2 inputs, a sub out, and a transfer line to the other speaker. Why two inputs? Dell has 5 jacks in this...
The speakers have two inputs for two different things, in my case I use the green input for my computer and the white one for my game consoles. You just need a 3.5mm minijack male to male cable to connect between the input on the speaker and the green jack on the computer.
Jan 14, 2011 | Altec Lansing Multimedia Computer Speakers
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
Can the Altec Lansing VS3251 5.1 work with a Xbox?
Because this system is made to work with the PCs, it has a 3.5 mm stereo input. The 360 has rca cable outputs. Fortunately, the signal is the same and all you need is a 3.5 mm to rca y adapter that you can find at radioshack or any local electronics store.
Apr 14, 2009 | Altec Lansing VS3251 Speaker
Sub Woofer to Sound Dock
Well if you are talking about the iM600 sounddock from Altec Lansing, the short answer is no. If you want better bass from an IPOD docking system you'll need to buy an expensive component from say Scandyna Dock or you could build one yourself. You would need an integrated amp or a complete system like the NAD C71. This would allow you to plug in a self-powered sub.
Dec 01, 2008 | Apple iPod classic MP3 Player
Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
May 15, 2008 | Altec Lansing Multimedia Computer Speakers
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
186 people viewed this question
 Grubhead
Grubhead
