Question about Sony PlayStation Portable (PSP) Console
Memory stick won't hold in psp
Does any body have any idea how i can sort out my problem with my memory sticks. i can insert them no problem but they just eject straight back out on the spring load mechanism.
  • 34 Answers
Hi hi had this problem the other day if u put in a differant card if u have got one it will insert and stay in
Posted on Aug 28, 2007
  • 709 Answers
Contact Sony PSP support and hopefully you have your reciept. Sony will refurb your unit if you have original receipt. www.playstationclinic.com
Memory stik problem
Have you tried another memory stick? Or have you tried this stick in another PSP? This will tell you whether the stick is faulty or there is something wrong with your PSP.
If the stick is faulty then buy another, otherwise take the PSP to a repair centre.
Apr 15, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
When I attempt to delete information from my psp memory stick a message states that there is no memory stick inserted
you might need to format u your memory stick in order to use it. insert the memory stick into your psp and go system settings, scroll down under system settings to format Memory stick.
Mar 07, 2010 | Sony PSP (Piano Black)
Any idea hw to restore psp games
Backup up your games on a PC. Then Format your memory stick and put the psp games back in the memory stick if this does not work try formatting your psp by entering the recovery mode HOLD R + HOLD POWER...
Go to advanced/advanced config/format flash 1 and reset settings
if this also fails try using another memory stick on your psp
Feb 18, 2010 | Sony PlayStation Portable (PSP) Console
Memory stick unreadable by psp
try formatting the memory card via a card reader..
thats all i can think of
good luck!
May 30, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
PSP is unable to read a memory stick
you should get repair your PSP. Then check if your memory stick work. For sure, the problem is on the PSP.
Mar 29, 2009 | Sony PlayStation Portable (PSP) Console
PSP 2000 MEMORY STICK SLOT PROBLME
Turn the psp on go to system settings then format memory stick then insert the memory stick and format it and it should be fine.
Jan 28, 2009 | Sony PlayStation Portable (PSP) Slim...
MY PSP SAYS NO MEMEORY
See if you can format your memory stick first through your computer than you might be able to format after with your psp.
Also Where did you get your memory stick? Depending on where you bought it (if you bought it on-line) it might be a fake. I would contact the seller for a refund or replacement if that's the case.
Jan 21, 2009 | Sony PlayStation Portable (PSP) Console
Sony PSP-1006
First of all do not insert memory stick in PSP ON mode and if you are using memory stick with red strip as shown in image so please try it with the bottom type as shown in image then too your problem is not solved it means in your PSP there is memory card module PCB which is faulty.
Aug 24, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
113 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
