Question about Ovens
Search Fixya...fisher and paykel wall oven, elements stopped heating???
Wall oven no longer working all of a sudden. used last night and is now just blowing cold air?? its a fisher and paykel model no B1600G. should i pull it from the wall and check behind for a fuse or something? everything else is working fine, elements not turning on at all (top & bottom)
barkencoa
  • 3463 Answers
SOURCE: smeg oven
Sounds like you need a new oven element fitting.
Posted on Dec 08, 2008
scottowa
  • 87 Answers
SOURCE: Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Posted on Mar 04, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
  • 8 Answers
SOURCE: Thermador SC301T heating elements not working (top
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Posted on Dec 11, 2009
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
Fisher and Paykel oven hot heating on fan force
Possibly a burnt out fan element. You or a service person needs to test the element & wiring with a multimeter.
May 10, 2016 | Fisher and Paykel Ovens
Fisher & paykel b1602cte oven fan in element at back of oven not working
FIRST YOU NEED TO KNOW JUST HOW THE FAN WORKS, DOES IT WORK OFF OF ELECTRICITY OR IS THERE A COMPUTER CHIP IT WORKS OFF OF. DOSE IT WORK OFF OF JUST A SWITCH. LOOK UP ON LINE TO FIND A MANUAL FOR A FISSER & PAYKEL B1602CTE IT MAY TELL YOU WHY IT IS NOT WORKING.
Jan 29, 2015 | Fisher Ovens
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
Fisher & Paykel double wall oven, bottom oven will not heat to set temp. Stops a 75 degrees
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Fisher and Paykel Titan OD301M Electric...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
I used the Self Cleaning feature on my Fisher & Paykel OS302 wall oven for the first time, and now the oven will not heat. The lights and fan run, but no heat.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 23, 2010 | Fisher and Paykel AeroTech OS302 Electric...
Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Feb 03, 2008 | Ovens
Ovens Logo
16 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
