Question about Brother MFC 420CN All-In-One InkJet Printer
Printer message: Unable to Print
My printer Brother MFC-420CN keeps showing the message, "Unable to Print," after it completes the start-up cycle. I'm able to use the Scan and Copy functions from the printer, and have whatever I scan or copy from this printer, printed out immediately on another printer connected to my computer. But I still can not print anything on my MFC-420CN. I went online and found a free service manual for the model MFC58 and learned how to put the printer on maintenance mode. I was able to get an error code, but since the manual is for the model MFC580 I was not able to learn the meaning of the code. The error code is 5A. Please any assistance with this matter will be greatly appreciated. Thank you.
  • 3 more comments
  • ken patel Dec 18, 2007
    i have brother mfc-440 cn printer and say unable to print 30 so please direck me to sole problem
  • Fritz Stoppelbein
    Fritz Stoppelbein Mar 15, 2008
    mfc 420CN will not print local or network
  • Anonymous May 11, 2008
    unable to print 5A
  • frd02maz Jun 07, 2008
    Error message "unable to print" is displayed, run through the recommended Brother maintenance, still not working. Any suggestions.
  • Anonymous Mar 16, 2014
    I can't do anything with the printer. It won't copy or print
  • 832 Answers
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Posted on Sep 10, 2007
    Habit-Forming:
    New Friend:
  • 81 Answers
5A means paper jam or some sensor error, but the common proble of unable to print 5A is mechanical they did not fuction to cleaning because of mechanical error, replace the mechanical then clean the sensor under the mechanical.
Posted on Oct 22, 2014
    New Friend:
My brother MFC 6490 CW message " Unable to print 50"
Posted on May 24, 2012
2 Suggested Answers
SOURCE:
Mix-it-up
  • 832 Answers
SOURCE: Printer message: Unable to Print
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Posted on Feb 20, 2008
Brother MFC-8820D Prints a COmpletely Black Page
You have a defective or disconnected SCANNER BLOCK
Mar 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Printer has unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
Then with the power on, pull the plug from the wall for several minutes. The plug it in and power the unit up.
Here is the manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 18, 2008 | Brother MFC 420CN All-In-One InkJet...
Error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-420CN
press menu then start b/k copy then fourtimes arrow-up (tel.index). machine will be in maintenance mode. press start b/k copy: What two digit error code does the machine display? Post here again.
To leave the maintenance mode press 9 then 9.
Mar 07, 2008 | Brother MFC 420CN All-In-One InkJet...
Feb 20, 2008 | Brother MFC-440CN InkJet Printer
This will be older problem
Unable to print appeared and I unplugged and plugged back in, IT WORKS! One time only. Then I gent the message unable to clean. It will scan to copy and print at random. Is this a mechanical problem?
Jan 30, 2008 | Brother MFC 420CN All-In-One InkJet...
Error message on my Brother MFC-420CN
press menu then start bk copy then fourtimes arrow-up button. Machine will switch to maintaenance mode. You may have to press start bk-copy. The machine will display an error code.
Error code starting with 4 is always a defective print head which needs replacing (except error 46: new waist ink tank needed).
In case it is another error code plz post here again.
Jan 28, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Nov 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Error message unable to print
Send it back. The printhead voltage is innnnn disorder. Netxt will be Error 41 (Every Error starting with 4 means probs with printhead and in 99,9% the head has to be changed and cant be fixed!)
Sep 20, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
3,990 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
