Question about GE DSKS433EBWW / DSKS433EBWH Electric Dryer
Service manual Dryer is not heating up when turned on. What would the possible problems be?
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: ge dryer model DVL223EA0WW service manual to replace heating coil
Try this website, they will have everything you need.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=2512&Acc=1&PPStack=1
Good luck,I hope this helps
Posted on Nov 13, 2009
How do I run the dryer on no heat setting?
From the Owner's Manual:
"F" Variables [F4 to F16] (Electrical problem)
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call for service.
I would say, before calling for service turn the machine off then unplug it for a minute then plug back in and try.
Jul 08, 2015 | Samsung DV331AEW Dryer
The dryer is not giving any heat.
Sounds like the heating element has burned out. If it's an older dryer then that's probably the case. If it's newer I would check the warranty.
Feb 05, 2015 | Fisher and Paykel DEGX1 Electric Dryer
Drum not turning. There is heat. Opened machine found broken belt. Drum will not turn by hand. What would it cost to fix?
in the package of the new belt, the belt for the dryer the instructions are right on or in the package, if not normally you take the front and possibly the top of the dryer 1st.... off slide the belt over the drum, and the insert it through the tensioner and then unto the motor. you have to make sure the belt has tension on it this will show it will be able to move the drum.... you can download maintenance manual form here
http://www.slideshare.net/avermapub/miele-gas-dryer-t9820-service-manual
price depends where you purchase it.. $ 20 to $ 45
Sep 25, 2014 | Miele T9800 Electric Dryer
Affinity Gas Dryer AGQ6000ES4 will not heat
Hi Margie, this is JK. I understand that your dryer is not heating. I recommend checking for possible restrictions in the venting or lint filter. Make sure that you have not accidently selected the air fluff or no heat. If you find that these settings are correct do a reset on the dryer by turning off the power for about 10 seconds and return power to the dryer. Turn on the dryer and select the normal cycle. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be a control board, high-limit thermostat, gas supply, igniter, or the sensor. Hope this helps!
Apr 01, 2014 | Frigidaire GLGQ2152ES Gas Dryer
I have a Maytag Legacy Series Electric dryer Mod # MDE508DAYW. The drum turns just fine but it is not heating up. I have had this dryer for approximately 3 yrs, 2 of which was in storage and not in use. I...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[]
Aug 09, 2011 | Dryers
I have a lg gromm dryer and it dosn't get hot when drying why?:
I suspect that either the heating element is malfunctioning or the control board is. Sorry but either will mean an engineer's visit ;-0(
Sorry again,
Good luck,
John C
Mar 25, 2011 | LG Washing Machines
Dryer runs and heats but drum won't turn.
you need to replace the belt on your dryer
Dec 26, 2008 | Whirlpool LGR8648 Gas Dryer
Dryer tumbles, no heat
Fist thing to check is if the manual reset on the heater box has tripped. That dryer can be serviced from the front. Also, there is a heater upgrade kit that can be purchased from Fisher Paykel Parts that has several updated parts in it for the top load electric dryers.
There are several things that can cause the reset to pop out. You may have a lint build up behind the shroud where the lint bucket fits.
This is a complicated appliance. You may wish to obtain a service manual for it.
Link to factory service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Link to heater upgrade kit:
http://fisherpaykelparts.net/index.php?categoryid=112&productid=32
Dec 17, 2008 | Fisher and Paykel DEIX2 Electric Dryer
Dryer works but won't heat
2 things ,,no heat whats so ever ,sounds like ignitor,, or little heat possible coils )gas)
Nov 29, 2008 | Frigidaire Dryers
White westinghouse
I have the same AEG T57800 dryer.  Problem, no heat. Couldn't find a service manual anywhere on the net. Checked for fuses and saw none. Thermostats on heater appeared fine, showing current flow. Replaced heating element 112 54 84 41/8, via local dealer - Respond Services from Electrolux UK in Durham DL5 6ED (£68), still no heat.  Called service tech who replaced the PCB - 973916012018008 (£135 + £85 callout charge). Very, Very annoyed at this as the dryer is only 3.5 yrs old.
Dec 11, 2007 | Dryers
GE DSKS433EBWW / DSKS433EBWH Electric Dryer Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
