Question about Garden
Model number 13AT604G401
Runs for 10 minutes then quits let sit for 10 minutes and will restart and run again for 5 minutes and stall again
  • 272 Answers
SOURCE: My tractor cuts out and dies, then with a recharge, it runs.
Not likely, if the battery is any good you should get several hours of run time before it dies. More likely low oil pressure cut off switch, check level or change oil if it's been awile. Or possibly an overheat cuttoff swith, check airlow and coolant if it has a radiator.
Posted on May 10, 2009
  • 12 Answers
SOURCE: 98 Honda Valkyrie Tourer, engine stalls
Check vacuum line from #6 intake runner (port side rear cylinder) to the fuel petcock valve. The valve is vacuum operated for safety. It cuts off fuel to the carbs when the engine is shutdown. Hose could be cracked or diaphram in valve is cracked. Easy to inspect the valve.
Posted on Jun 07, 2009
  • 33 Answers
SOURCE: Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Posted on Jul 04, 2009
  • 39 Answers
SOURCE: It Starts and runs fine for about 15 minutes then
Chances are the gas vent (or gas cap vent, as the case may be) or air or gas filter are clogged or dirty. replacing and/or cleaning them should take care of the prob.
Posted on Jul 28, 2009
wilsodfarm
  • 986 Answers
SOURCE: 1942 farmall tractor stalls after 10 - 15 minutes of bushhogging.
I think you still have a fuel issue like your float level is to low,I hope this helps you
Posted on Sep 10, 2009
My mtd mower with 15.5 hp engine starts and runs for 5 to 10 minutes and quits. It will usually restart with the choke on and run for a few minutes more and quit again. It will finally not restart.
More than likely a carb problem. What kind of fuel you use makes a difference. If ethanol, causes corrosion inside carb. Or maybe something easy as air filter.
Jun 03, 2016 | Mtd Garden
Why does motor quit running after 5 to 10 minutes
Check that the vent in the fuel cap is not plugged. Can create a vacuum preventing fuel getting to carburetor,
If not sure leave cap a little loose and see if stall repeats>
Mar 11, 2016 | Ariens Garden
Husqvarna 61 inch zero turn model ZTH6125 Engine cuts out.
Sounds like the safety switch may have stuck. Allowing it to set, the switch "released". Just my guess.
Apr 18, 2015 | Husqvarna Garden
Ford excursion 2002 - starting fine but losing power and stalling after running for 10 minutes. Rest for about 5 minutes, then starts up again
Can you perform a spark test? I would like to know if it has spark when it stalls. Also, if you have a can of starter fluid, wait for it to stall and not want to restart, the quickly spray some starter fluid into the intake. If it runs on the starter fluid, you have a fuel issue. You might also want to make sure the engine coolant level is fine and you aren't overheating. If you coolant level is low you may not know it is overheating since the coolant sensor isn't in coolant. It won't read air.
Jan 28, 2014 | Ford Excursion Cars & Trucks
1976 FORD F-100 STRAIGHT SIX Stalls after driving a few miles will restart after a few minutes but stalls again soon after. The longer it sits the longer it will run and drive. I have replaced the fuel...
Sounds like the ignition module on the fender.
You would need to know if you are missing spark to the plugs when it quits running. The carb would not run out of fuel then suddenly have fuel again.
Jan 30, 2013 | Ford F-100 Cars & Trucks
Toro Proline 52" stalls out after warming up
Do you know if that unit has a fuel pump or not? If not, then engine vacuum is what draws the fuel in ... but only IF the hoses involved DON'T have any cracks or splits, and they fit TIGHT on the ports to which they connect! Try using an eye dropper and squirt a little gas in the air intake under the air cleaner. Does it fire then?
Apr 19, 2017 | Garden
Amana Electric Dryer Model NDE 7800YW squeals when running will quite after 5 to 10 minutes
my amanadryer will run for 10 minutes and then start squealing and quit.wait 15 minutes and it will restart and do the same thing. any help???
Mar 09, 2010 | Dryers
Suburban stalls while driving after running for 15-30 minutes. After letting it sit for 5-10 min it runs fine for another 5-10 minutes, then starts doing it all over again.
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Oct 07, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Stall will driving
Have you ever change the fuel filter? if not then try this
Jun 12, 2008 | 1991 Volvo 240
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
