Toshiba touchscreen all in one desktop
I cannot get a display onto the tv from my computer, I am using a HDMI good quality cable.
  • 7,733 Answers
You need also set your tv to use the hdmi.So go to your tv settings and select the proper connection.
Posted on Jul 15, 2013
bunnydawg
  • 5158 Answers
SOURCE: no signal from hdmi
there should be a couple keys you hit to toggle it to the external monitor (tv) look in the manual... if you don't have the manual you can download it here www.sony.com
Robert
Please take a moment to rate this solution.. thanks
Posted on Jan 26, 2009
  • 220 Answers
SOURCE: Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Posted on Jun 26, 2009
pabloloco
  • 2335 Answers
SOURCE: hdmi to panasonic tv no desktop display only
I can help with getting your desktop onto your TV, but sound from your computer through HDMI can be much trickier.
If you only see a background picture on your TV, then your desktop has been either "extended" or "stretched" onto it. It is essentially a second independent monitor and you can drag applications over to it to see them.
To view your desktop and start menu on your TV, you need to run ati catalyst and "clone" your TV with your computers monitor. Do this by right clicking the picture of the second monitor in the catalyst display manager and choosing "clone". Now your tv and your monitor act as one.
Although i tried 3 different ati cards with hdmi outs that claimed to pump audio through hdmi, none of them worked for my HP PC. You will need a grey widget adaptor between your computer and the hdmi cable. In the end though, there's a conflict between my sound card and ATI's HDMI audio that cannot be resolved. So I run a digital SPDIF signal instead through an rca cable and get 5.1 dolby at my amp that way. Good luck.
Posted on Sep 20, 2009
parrotheadpc
  • 2600 Answers
SOURCE: HDMI to HDMI
We are running our DV-7 with a 20 foot high quality HDMI cable with no frop out or interference. The DV-7 has a decent video chip and will push the signal without incident.
Posted on Aug 01, 2010
Testimonial: "Exactly the information I needed. Thanks for the quick and "right on point" response! What a great site!"
buzzpuppy
  • 36 Answers
SOURCE: How do I conect my Acer aspire 5750 lap top to my
"Out of range" means that the picture displayed by the laptop cannot be displayed by the TV, either because the resolution is not supported or the refresh rate is not supported.
Sometimes, I've had to set the refresh rate (from the laptop Display settings) to 59Hz to get it to work as opposed to the default 60Hz.
What resolution does your TV support? What resolution does the laptop support?
Matching these as closely as possible and you'll get the picture on the TV screen.
Good Luck and let us know how it goes,
-BuzzPuppy
Posted on May 01, 2011
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
Tip
USE YOUR LCD TV AS A COMPUTER MONITOR BY WAY OF HDMI.
To use your LCD TV as a monitor. look for a HDMI output on the computer and the TV. If you dont have a HDMI output on the computer, you will need to spend approx. $70 for video card and install it. I found "VisionTek Radeon HD 4350" to work fantastic.. Make sure your LCD TV has a HDMI INPUT. If not, you will need a newer TV. All thats needed now is a HDMI CABLE. The cable can be purchased anywhere computers are sold for between approx. $30 to $40. Depending on length. The cables can be found for much less ON-LINE. firefold.com has the cables for approx. $5. and they are the high quality gold plated cables. Now plug the cable into the computer and the TV and then using your tv remote, switch to HDMI and your tv is now a computer monitor. "Note"you may have to make adjustment on computer for display size and quality. My LCD TV is a 46" and the video card described above supports HD full screen. A wireless mouse and key board are a nice feature to add. If you like movies, you can get netflix and stream movies. there are many other sites for streaming and downloading. after doing this with my computer, i dont have a cable bill any more..I hope this tip helps.
on Dec 02, 2009 | Computers & Internet
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
How do i connect my laptop to my dynex tv?
This depends on your hardware. If you have HDMI port on your laptop and on your TV it is the best and easyest option for your case. Just plug-in the hdmi cable, go to your computer Control Panel->Display and configure the second monitor as extended. Your TV must be monitor number 2 and you should use recommended settings for the picture resolution.
From your TV go to input source list and select the HDMI port.
Now you should see your desktop background without the taskbar and icons. So you can drag and drop the application you want to see on your Dynex TV(secondary monitor) and that's it. This method will bring video and audio just with one cable. Of course you can use VGA port on the Tv, but the quality of the picture will drop and you must have separate cable for the sound.
May 28, 2012 | HP Computers & Internet
Can not hook up to my Toshiba TV what cord do i need in order to make it work
Since this model of All-In-One Computer already has a built-in Digital/Analogue Television Function, as part of its standard specification, I will assume that your reason for wanting to interconnect these two devices is that you want to export computer, internet or other IT-based multimedia images to the TV for an enhanced viewing experience due to the TV's larger screen size.
The All-in-one computer has a High Definition Multimedia Interface (HDMI) Port.
If the TV also has an HDMI port, what would be required is the best quality HDMI Cable that the User can afford.
All electrical/electronic interconnections between cables and ports suffer some degree of degradation or dissipation of the signal traveling along the cable. The most efficient metal for electronic connections is gold due to its comparatively high level of electrical conductivity compared to that of other metals used for electronic interconnections.
The best cable choice would therefore be a gold-plated HDMI Cable (see below).
If the TV has no HDMI port, an HDMI to Video Graphics Array VGA Cable Adapter or ([Victor] Radio Corporation of America - the inventors) RCA/PhonoVideo Cable Adapter between the HDMI Cable leading from the computer and the corresponding VGA or RCA/PhonoVideo port on the TV should resolve the connectivity mismatch (see images below).
Once connected, the TV Remote Control should be used to change the Signal Source Input from its automatic standard (Default) setting to PC Input:
Menu -> Source -> PC -> OK.
Nov 25, 2011 | Acer AZ5700-U4002 23-Inch All-In-One...
I have windows xp and would like to use my sanyo flat screen to veiw movies that are downloaded on my computer
Purchase an appropriate cord depending on the connections on the back of your pc, you will probably need a dvi - hdmi or vga to dvi
use the cord to plug into the television
then right click on the desktop go to properties find the tab that has pictures of two blue boxes select the one that is dimmed and click the box extend my desktop onto this display then hit ok.
May 11, 2011 | Computers & Internet
Hdmi to panasonic tv no desktop display only
Sep 20, 2009 | Acer Aspire 3000 Notebook
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Computers & Internet Logo
David Payne
David Payne
