Back to:
Tags:
System Power Supplies
Generic problem for all System Power Supplies
Power Supply
posted by bobzy59 on Aug 27, 2007
I just purchased a compaq presario 6000 desktop on ebay and i think something must have been dislodged during shipping because when i try to turn it on, it comes on very briefly but then goes back off and a red LED light in front begins to blink. Ive opened it up but i dont know what to look for. Any ideas?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 28, 2007
FixYa! (100)
Huty
Rank:Master Master
Rating: 76%, 23 votes
I would to make sure all the power plugs on the inside of your computer are snuggly secured. Also check to make sure the RAM sticks are plugged in correctly and that the processor is present and in place.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Power Supply:
I don't want to Accept this solution
Solution #2
posted on Nov 19, 2007
Not Rated (0)
mrpc2008
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This problem occured for me. The Presario 6000's Power Supply has a small two prong power connector that hooks to the motherboard. Without this plugged up I found that the CPU fan wouldn't work and the CPU overheated causing the PC to cut off. So if this is of any help, look to see if there is a two prong power connector on your power supply and if so, plug it into the two prong connection slot and see if this helps your problem.
Good Luck! Jeremy
Thank You!
Solution #3
posted on Nov 12, 2007
Not Rated (0)
RachelR
Rating: 0%, 0 votes
We had the same problem with our Presario 6000 when it was fresh from the box - within the first week. After haggling with Compaq they exchanged for a new one, but soon after replacement we had the problem arise again intermittently. We tried troubleshooting it for several years to no avail.
Eventually we broke down and took it to our very trusted tech repair man said that the power supply was a POS and replaced it with another -completely autonomous - power supply and it has been fine since. Good luck!
Thank You!
Solution #4
posted on Oct 03, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
If the processor is installed. It sounds like the CPU is overheating. Remove the heatsink and put new thermal compound on and reinstall Processor
Thank You!
Solution #5
posted on Sep 26, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
I have the same problem. I even opened the power supply where I think the problem may be. Before I start to measure electronic components I will try to vacuum clean it all: sockets, components with care.
In my case the computer was working and suddently it shut-down with no warning or error messages. Simply went off.
If you have news about this log here. Today I will try to make it work.
You spoke about a shipment: that gives me one idea: it may be broken solding points. With an hot solding iron try to rectify (with care and after all capacitors in the power supply are discharged to avoid electric shock) those soldures.
Best regards,
Daniel.
Thank You!
Can you Help with these System Power Supplies problems?
i am on aol and i keep getting disconnected and its always...
Sun DPS-680CB (300-1501) 680-Watt Power...
How...
HEC Group ACE 580UB 580-Watt Power Supply
i already buy this power at yesterday and when i connect...
I just read your solution to a problem that I have been...
Toshiba PA2502U - Libretto 100, 110, 100CT,...
There suddenly was no power and I was wondering could this...
Loading problems.
Repair Service
Find System Power Sup. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
