Question about Charging & Starting Systems for Chevrolet Caprice Classic
Charging & Starting Systems for 1970 chevy c 10 truck
Altonator wire color code
    Top Expert:
  • Chevrolet Master
  • 12,223 Answers
See the diagram attached. God bless you
Charging & Starting Systems for 1970 chevy c 1 - 12f5e882-3a25-4757-a72a-ab1358441f8f.jpge48ad75f-ea7b-472e-aad7-a88a3664298e.jpg
Posted on Jul 15, 2013
My 1970 chevy truck overcharged only when headlights are on
Have your alternator tested it may have a burnt diod.
Apr 09, 2014 | Cars & Trucks
Dimming lights while driving
could be bad ground or altenator
Dec 05, 2012 | 1997 Chevrolet Blazer
1970 CB450 charging problems. Just looking for a demonstration how to check the magneto, stator and rectifier, and maybe a quick explanation how to replace them
Being a 1970 vehicle you have the older copper oxide rectifier,if you have charging problems,that type of rectifier output usually drops to about 1/2 battery voltage. It is located under the seat between the back fender and the bottom bar that the seat rests on,also more often than not, you get a really strong odor of rotten egg smell from a defective copper-oxide rectifier. Solution, replace with a 6-10 amp bridge rectifier from Radio Shack. Your charging voltage should be in the range of 13.8 -14v@ 1500 rpm.
Dec 03, 2012 | Motorcycles
72 cj wiring
The best way to find out what you are looking for is to go to your local auto parts store or the local library and check out the wiring diagram manual for the year you posted
Jun 26, 2012 | Charging & Starting Systems for Jeep CJ5
Do you know the wiring diagram for the dash cluster on the olds 442 1970... which includes oil pressure, temperature, gas gauge, brake, and generator light. Do you know the color code/order? I need to know...
That is an older car. A schematic may be available on a Google search. Chiltons and other repair manuals often do not have electrical schematics.
Sep 03, 2017 | 1970 Oldsmobile 442
New battery , wires and plugs and still have trouble starting in the mornings, get a jump and starts. After running vehicle for awhile I turn it off and try starting it it will start.
check alternator output with engine running.you should have 13.5 - 14.5 volts if not alternator not charging.check alternator wiring to battery feed to alternator.check alternator voltage regulator wiring check alternator fuse make drive belt not slipping.and you have the correct cold cranking amp battery.bad old worn out battery cables will cause charging problems.because old battery cables put high resistance on the charging circuit.if battery cables old as vechicle replace them.
Apr 15, 2011 | 1994 Chevrolet S-10 Blazer
MTD yard Machine lawnmower,17hp Briggs And Stratton engine. Runs for about 15 or 20 minutes and stalls. It will not start again until I recharge the battery over night. Then only runs again for 15 or 20...
yes it could be
check your battery 1st , then check the stator a/c output
• 10 or 16 Amps DC regulated for charging
battery
• Two black leads (C) from stator
• Yellow connector (D) with two pin
terminals
• Two yellow leads (E) to regulator-rectifier
(F)
• One red lead (B) from regulator-rectifier
to red connector output lead (A)
• 10 and 16 Amp systems use the same
stator, color coding and regulator-rectifier
• Alternator output is determined by the
flywheel alternator magnet size
The stator and regulator-rectifier are the same
for the 10 and 16 Amp systems. The system
output is determined by the flywheel magnet
size.
Test Alternator Output
1. Temporarily disconnect stator wire
harness from the regulator-rectifier.
2. Insert RED test lead (A, Figure 28) into the
V ω receptacle in the meter.
3. Insert BLACK test lead (B) into COM
receptacle.
4. Rotate selector to AC Volts position.
5. Insert RED (A) and BLACK (B) test lead
probes into output terminals (D & E) in
YELLOW connector (C). (Test clip leads
may be attached to either terminal).
6. With the engine running at 3600 rpm, the
output should be no less than:
• 20 volts - 10 Amp System
• 30 volts - 16 Amp System
7. If No or Low output is found, check for
bare wires or other defects. If wiring
defects are not found, replace the stator.
voltage depending on alternator type and magnet size
then check the regulator / rectifier , make sure it is grounded properly
make sure battery earth lead is good
i suspect loss of bat voltage is letting the afterfire solenoid close off the main jet
let me know model and type codes off engine & i will try help further
cheers
Aug 29, 2010 | Briggs & Stratton Garden
Auto electricl wiring size and color
I have been restoring cars for years and in my opinion the absolute best/easiest way is to buy a new harness kit from "Painless Wiring" it will include a complete harness and fuseblock, the wires are all labeled so there really isn't any guesswork.
Feb 25, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
Problem starting
Depends on the Type and Brand of the Scanner. From Experience these Codes are for the Ignition System. Check the Coil, Plugs and Plug Wires, Distributor Cap and at the Extreme The Fuel Pump and Filter. Let me Know what you Find!
Dec 19, 2008 | Bulldog Remote Starter & T-Harness Kit for...
1970-1980 chevy lightswicth replacement assemble diagram
  • Terminal B = battery
  • Terminal A = fuse
  • Terminal H = headlights
  • Terminal R = rear park and side marker lights
  • Terminal I = instrument panel lights
  • Terminal D1 = dome feed light
  • Terminal D2 = dome light
  • Oct 25, 2008 | Chevrolet 1972 Blue & White Chevy Pickup...
    Charging & Starting Systems for Chevrolet Caprice Classic Logo
    71 people viewed this question
    Top Chevrolet Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Mike
    Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
