Question about Exercise & Fitness
How the error e02 on fit king treadmill be repaired
Fit king tread mill either stops in the middle of running or don't start at all showing E02 error. how to fix it?
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Posted on Jul 24, 2015
5 Suggested Answers
SOURCE: What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Posted on Feb 12, 2010
  • 8 Answers
SOURCE: Carl lewis treadmill
On mine it was the micro switch that senses the rotation speed. The switch is static and placed my a moving magnet usually inset into the drive pulley. The wiring from the sensor could also be faulty.
Posted on Mar 26, 2010
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
mark24354
  • 776 Answers
SOURCE: The machine keeps saying E02.It
There are only a few manufacturers of treadmills and they put a bunch of diffierent brand names on them. The E02 error is most likely a "no power to motor" error. Open it up and make sure the electical connectors to the motor are firmly attached. Hopefully this the problem and it is easily solved.
If it is more than just the wire attachement, it might be the fuse for the motor or, a bad motor control panel (this would be the most expensive option and likely not worth replacing. Look for a glass fuse (glass tube with metal on each end) and see if it is bad. The elevation motor might have a separate fuse so look for both.
Good luck
-Mark
Posted on May 22, 2011
Error message E02 on Reebok ZR8 Threadmill - please help if possible
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 01, 2016 | Exercise & Fitness
Tread mill display start and work stop and E03
You have to check whether the Motor runs before its shows the Error E#. If so you have to check the speed sensor. Can be it displaced or faulty. You will find the speed sensor near the motor pulley.
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
Jun 22, 2016 | Exercise & Fitness
Why does my t210 treadmill stop and then come up error e02?
Hi this is due to the treadmill's belt speed loss.
This happens if the motor is faulty or if the belt is stopped suddenly due to too much weight on it or misuse.
I would have the motor checked if I were you.
Feb 08, 2016 | Exercise & Fitness
Davina treadmill motorised jx-622w wont start display says e00
E00 Means the red magnetic key (the one on the string) is not inserted.. If it is then the magnetic switch may be faulty.
E01 Is an electrical fault - the wire that runs inside the frame is probably crushed while assembling
E02 Means the motor is not running - either burnt out, stuck or the optic device is not functioning correctly.
This are what I found out by trial and error - hope its useful to someone - I'm looking for a copy of the manual for this thread-mill if anyone could send me a scan or photos of the pages - thanks very much.
Mar 17, 2013 | Exercise & Fitness
Oma-002mb what the weght can this tread mill work my weght is 125kg can i trainning in this tread mill
yes you can every treadmills made for hourse training can weight for 250 lbs aprox.
Happy new Year.God bless you
Dec 31, 2012 | Star trac ST Fitness 8921 Treadmill
I also have this problem. I rang Carl Lewis Support and they said to check the connections on the circuit board (Located in the floor panel next to the motor). If the treadmill had recently been moved something may have been dislodged. I checked mine and found a few loose wires and plugged them fully back in but this didn't help my treadmill. I'm awaiting a response from an e-mail i sent them now.
Jul 06, 2009 | Exercise & Fitness
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
Exercise & Fitness Logo
946 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
