Question about HP Color LaserJet CP2025DN Printer
My hp color laserjet cp2025 has the error 79 - HP Color LaserJet CP2025DN Printer
  • 81 Answers
SOURCE: HP LASERJET M1522 NF 79 error what is it?
The unit has encountered an internal firmware error. If it's plugged in to a surge protected extension lead then remove it and plug it directly in to the wall socket. Retry the printer. If this fails again, then it looks like it would have to be a formatter replacement on the printer
Posted on Oct 13, 2009
  • 223 Answers
SOURCE: My hp color laserjet cp2025 has the pcl xl error
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
Posted on Jul 13, 2010
SOURCE: HP Laserjet CP2025
The yellow flashing light shows network activity and is quite normal. It flashes every time a message is sent anywhere on the network.
Posted on Jul 22, 2010
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
Posted on Jul 26, 2010
seeker5211
  • 1089 Answers
SOURCE: Colour laserjet HP cp2025 keeps
It's normal. The printer is designed to go into a cleaning cycle to maintain good print quality. Depending on your environment It could run every 50 pages or every 100 pages. You can't turn it off or modify it.
Posted on Oct 11, 2010
How to reset and/or clear error message on an hp cp2025
This sounds like bad jetdirect card causing it..problem is new HPs have them integrated and they can not be replaced. If a firmware update does not fix it, then a call to HP would be the best bet
Dec 06, 2016 | HP Color Laserjet Cp2025 Printer Laserjet...
Getting 79 ERROR on CM1015 printer. Printer shows error then powers off and repeats.
Error 79 indicates a internal memory error, specifically, it can indicate the internal memory is full. You can try printing the printer's test page, it shouldn't fill the memory and it should print. Here's a link to the official HP error 79 trouble shooting instructions for the CM1015.
HP Color LaserJet CM1015 MFP and CM1017 MFP Series Printers Control Panel...
Jan 25, 2015 | HP LaserJet CM1015 All-In-One Printer
HP color laserjet cp2025 will not print. Help.
No.
Very few printers will print if they're out of toner, even if the colour toner is exhausted and the print job is only black. Replace the empty toner and if this is the only problem, the printer will continue printing.
Jan 20, 2015 | HP Laserjet Cp2025n Printer
I have a 1" wide black smear on the right page edge when using my HP CP2025. Any ideas on how to fix this?
clean the drum if you can get to it easily and also the toner but you may need a new toner and/or drum
Nov 28, 2014 | HP Color Laserjet Cp2025 Printer Laserjet...
How to solve 57.01 error turn off then on in my hp color laserjet cp2025 printer
57.xxx codes almost always indicate a cooling fan problem. One of your cooling fans has probably ceased to function, the fan will most likely need to be replaced.
Sep 05, 2014 | HP Color Laserjet Cp2025 Printer Laserjet...
57.xxx codes almost always indicate a failed cooling fan. The fan will probably need to be replaced to get rid of the error code.
Hp color laserjet cp2025 10.1000 supply memory error
Hp color laser jet cp2025 10.1000 supply memory error solution
May 30, 2012 | HP Office Equipment & Supplies
HP Color LaserJet CP2025DN Printer Logo
1,352 people viewed this question
Seeker5211
Seeker5211
