Question about Radio Communications
Kenwood Nx 210 key pad is locked? How do I unlock, not knowing which key was pushed to lock it in the first place?
Tried removing battery Tried pushing every key
SOURCE: kenwood tk270g
it has to be performed with the computer program that was used to program the channels on the portable radio.
Posted on Jan 25, 2008
SOURCE: Locked out!
press c for a long period of time
Posted on May 11, 2008
baccardo
  • 150 Answers
SOURCE: 2005 mazda 6 locked radio
push the 2 and 3 key to enter a code
Posted on Apr 16, 2009
kawawa
  • 119 Answers
SOURCE: Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Posted on Jun 18, 2009
SOURCE: i have a kenwood tk-272g and the keys are locked
One of the keys has been programmed as the lock button. you will have to experiment by holding each button for a couple of seconds until you hear a tone that tells you the radio is unlocked.
On the one I have for our fire and rescue it is the < button but it could be any of the four on the front or the two on the side below the talk button.
Posted on Jun 19, 2009
Locked
Press and hold the key programmed as
[Key Lock]
for
2 seconds to lock the transceiver keys. Press and hold the
[Key Lock]
key again to unlock the keys.
LOCKED
appears when a key is pressed while the keys
are locked
Mar 05, 2014 | Kenwood Radio Communications
Driver doorr does not unlock when you press the remote
Hi. It sounds like the door lock has failed. This would need to be replaced. You will have to break the door pad to access the lock.
Feb 24, 2014 | 2002 Volkswagen Golf
1999 saab 9-3 driver's side door will not lock
Sounds like the linkage came off, remove the door panel and inspect
Feb 09, 2013 | 1999 Saab 9-3
My keyless entry pad stopped working replaced the battery and still will not work. I have a 2001 ford taurus ses. how do i resolve this problem by reprogramming the keyless entry pad? I tried the code lock...
Try it with a new remote pad, turn the key back and forth untill the locks jump up and down.. do it slowly , when they jump make sure to leave the key in the on position while pressing both lock and unlock buttons on the remote, they should then jump again telling you that the remote is now programed.
Apr 14, 2011 | Ford Taurus Cars & Trucks
My keypad is locked.please help me
ky keypad is locked by security code what can i do 4 unlock 2730c
Aug 12, 2010 | Nokia 2730 Cell Phone
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Frozen radio
''key-pad" locked, unlock by pushing two buttons at he same time, check your manual for which two buttons it is on your type of kenwood.
Dec 13, 2008 | Kenwood DNX5120 DVD Navigation System GPS...
Remote lock for back doors and rear tail gate door
Actually I found a solution. I remove the lock relay form the fuse panel and placed it back in place. I did not replace it. After doing this they worked. I probably need to replace the relay at some point, but for now that solved the problem. It was hard for me to believe that there is a separate relay for the lock and unlock circuit.
Sep 28, 2008 | 2005 Chevrolet Suburban
Password
i have the kvt-815dvd and i just did this this morning get any kenwood remote that has a 10 digit key pad on it push the reset button and you have to do this fast as soon as the lights come on saying there is power but before the display lights up press this in this sequence
55
222
77 then track next button do it quickly and it will work i tried it a few times a little slower and it didnt work so you have to do it pretty fast i didnt hit enter or anything i just pressed the digits it stands for kcar on the number pad so try it
Aug 28, 2008 | Kenwood KVT-715DVD Car DVD Player
Ignition
See Procedure for REPLACEMENT.
1. Disconnect the negative (-) battery terminal. 2. Remove the crash pad side cover (A).4862483.gif 3. Remove the ignition switch (A) after loosening the screw and disconnecting the 6P connector.e5d4d9c.gif 4. Remove the steering column shaft (Refer to the ST group). 5. Remove the key warning switch and key illumination lamp (A) after loosening the screws and disconnecting the 6P connector.1ceff53.gif 6. If it is necessary to remove the key lock cylinder (A), Remove the key lock cylinder (A) after pushing lock pin (B) with key ON.5d997e5.gif 7. Installation is the reverse of removal procedure
Jun 14, 2008 | 2007 Hyundai Sonata Limited Sedan
Radio Communications Logo
320 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
