Question about Dell Inspiron 6400 Notebook
My mic has stopped workin again !st time i had my motherboard replaced and had sound driver uninstalled and reinstalled then it worked.now its gone again works abit when wiggled in socket I uninstalled driver but now cant find it need help with driver and mic
    Sergeant:
  • 279 Answers
If it works when you wiggle it in the socket, it's not a driver issue. It's either a problem on the motherboard again, or a short in your microphone cable. As replacing a microphone is a lot easier than replacing the motherboard again, I'd suggest finding another microphone, plugging it in and seeing if that fixes it. If it doesn't, I'm afraid it's the motherboard.
Posted on Aug 28, 2007
SOURCE:
I plugged in microphone but its showing it was not plugged in and my o.s is vista
Try to uninstall sound driver and reinstall sound driver again.
1. First solution : go to control panel, then system , device manager and select sound audio device , right click and uninstall the driver and restart the computer.
2. Soulution : check in system bios setup is there is any option available for mic enable or disable from there ?
3. update the sound driver.
4. check mic is working in another computer
Dec 29, 2010 | ASUS M2N-E SLi Motherboard
Sound driver stops workin after some time.. mine is 64 bit os
ok try installing realtek new version that will surely work but first uninstall the older audio driver
Mar 01, 2010 | ASUS A8V-VM Motherboard
Error: PCI on motherboard and strange wireless/driver issues.
just remove the CMOS battery and restart the pc
worked for me.
Aug 27, 2009 | Gateway M460 Notebook
Sound drivers
realtek sound driver of D945GC NOT LOADING SHOWING FAILED IN XP FORMATING.PLEASE HELP.
Jul 09, 2009 | Intel D945GCL Motherboard
Mic not working in Asus-KPLCM motherboard
This MIGHT be a driver related problem, but it could also be build problem. Are using the front panel outlets or the rear on-board outlets?
If its the front ones make sure they are going to the right sockets on the motherboard.. if its rear outlets from the motherboard then its definitely a driver issue.
However, check where the CD audio cable is going to on the M/B first.
Mar 19, 2009 | ASUS P5LD2-VM Motherboard
GMA 4082n device driver not working properly code 39
sounds like your cd/dvd is mechanically shot. time for a new one.
Mar 09, 2008 | Lenovo 3000 C200 Notebook
Audio problem regarding win xp with D101 GGC
i see all driver less vista.
i enclosed the link.
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2229
Feb 29, 2008 | Intel D101GGC Motherboard
Microphone
Open system properities. click hardware tab & than device manager. Scoll down to Sound, video & game controller. Do you see a yellow ! point there. That means the driver may need to be reinstalled. Asus is famous for having defective mic controllers & yes the sound works but no mic. You can also open control panel open sound & audio devices. You should have the same device under Audio & Voice. If you do, again your intergrated mic controller is bad. Your manual most likely will not have the correct number to call tech. They moved in 07. So I'll put it in here: 812-282-2787Tech IL Eastern Time. Good luck!
Please vote...........
Jan 15, 2008 | ASUS M2N-MX Motherboard
Inspirion 6400 Mic Problams(win Vista)
Try visiting the DELL web site and look for the software there as for the mic it may be loose inside the enclosure carefully open it and check for lose cables or screws
Aug 27, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
82 people viewed this question
Ekse
Clive
Clive
