Question about Plumbing
Hydraulic press foot pedal not engaging
  • 3,368 Answers
I think you have posted in the wrong area. More informtion is needed such as model etc. Is the foot pedal electrical or ???
Posted on Jun 18, 2014
Can this inspection and removal of the Clutch actuator components be done without removal of the Bellmouth.Would the unusual hissing sound on depressing the Clutch Pedal indicate an airlocked system?
there is no air in a hydraulic system or if there is , the clutch will not disengage
if you have any sound when depressing the clutch pedal, it is most likely from the throw out bearing running dry when pressure is applied to the pressure plate fingers
so it amounts to this
if you press on the clutch pedal and you can readily engage first gear or reverse and you have steady operation when you take your foot of the pedal , the clutch system is working as it should
that means that any noise you get when pressing on the pedal is when the throw out bearing is placed under load and as there is no other part that is moving, that is the logical area
one point here --if it is an air noise and of that you are sure , when people press on the clutch pedal, to stop vehicle movement they also have the foot resting or pressing on the brake and a hissing noise here can be from a vacuum leak at the brake pedal from the brake booster
easy to check before pulling a box that doesn't have a problem
Sep 17, 2016 | 2002 Land Rover Freelander
The clutch pedal of my Toyota Hilux kzte 2004 does not want to release on its own.
I assume that means that the clutch does not engage/disengage when you press and release the pedal. There are a number of possible issues here. First, does the pedal feel "soft"? Is it easier to press down that usual? If so, the problem may likely be in the hydraulics of the clutch. A bad master or slave cylinder will not allow hydraulic pressure necessary to engage/disengage the clutch.
If the pedal feels normal, then the problem is most likely internal to the clutch mechanism. A bad release bearing or a stripped clutch disc are the most likely culprits for this issue.
Sep 10, 2016 | Toyota Hilux Cars & Trucks
Hard to press clucth /hiace 2014 .while to engage hard to press clutch
check the clutch operation if it is hydraulic--press the pedal and see if the slave cylinder movers the throw out arm
It suggests a problem with the clutch master cylinder or a failed hose in the system that blocks off when the pressure is applied
hard to select the gears indicates that the pressure plate is not releasing
if it is a cable operation then replace the cable assembly as it is jamming up inside.
Aug 09, 2015 | Cars & Trucks
Murray ride-on lawn mower model 155/107 (15.5 HP Briggs & Stratton engine). Engine starts o.k. but cuts out as soon as the hydraulic clutch is engaged via foot pedal. ie foot on clutch to start...
two possible problems. check power from safty switchs, put the lever down under the seat and rock the back tires back and forth until you here a click. then try again. a safty swith is giving you problems
Apr 25, 2011 | Garden
The clutch pedal sticks down when trying to engage
YOU DO NEED A NEW DISC AND MOST LIKELY A MASTER AND SLAVE HYDRAULIC CLUTCH CYLINDERS, THE STICKING MAY BE DUE TO OVER TRAVEL DUE TO THE WORN OUT DISK.
May 11, 2010 | 1998 Ford Ranger SuperCab
UNABLE TO ENGAGE GEARS WHEN ENGINE RUNNING ( CAN ENGAGE GEARS WITH ENGINE OFF ). CLUTCH PEDAL GOES STRAIGHT TO THE FLOOR WHEN PRESSED
Need to have it check could be clutch master cylinder or slave cylinder or hose from clutch master cylinder to slave cylinder.check brake fluid at clutch master cylinder sit next to brake master cylinder if empty could have a leak. fill and pump peddle and look for leak.
Jan 12, 2010 | 2001 Ford Focus
As soon as i turn it on, the needle starts moving up and down even though i don;t have my foot on the pedal at all.
as you turn on the motor starts running. but when you press pedal there is a clutch that engages. probably the clutch keeps engaged. clutch needs to be set to engage on pressing pedal only.
Nov 06, 2009 | Singer Sewing Machines
The clutch pedal went all the way in suddently
U ARE GOING TO HAVE TO REPLACE EITHER THE MASTER CYLINDER OR THE SLAVE CLUTCH HYDRAULIC CYLINDERS, I HAVE FOUND IT BEST TO REPLACE BOTH CYLINDERS AT THE SAME TIME.
MASTER CYLINDER
92a5a10.jpgSLAVE CYL
Feb 05, 2009 | 1997 Honda Civic
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
