Question about Sewing Machines
Threading pfaff hobbylock 4870 - Sewing Machines
SOURCE: manual
I have an extra copy of the manula for the PFAFF 783 Hobbylock. It cost me $12 plus $2 postage when I bought
it 4 years ago. Write me if interested. TRKSOCREF@aol.com
Posted on Nov 28, 2007
  • 3 Answers
SOURCE: Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Posted on Jan 13, 2009
  • 632 Answers
SOURCE: lost instruction manual
ebay
Posted on Jul 17, 2009
SOURCE: Threading Diagram Pfaff 774 Hobbylock
Here is how:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Pfaff_Sewing_Machine_Threading/Pfaff_774_threading_Diagram.htm
Posted on Dec 28, 2010
trial2962
  • 107 Answers
SOURCE: pfaff 795 hobbylock manual
There is eBay item 160737677765 with this manual I found for you.2_15_2012_2_36_56_pm.jpg
Posted on Feb 15, 2012
I need a video on how to thread a pfaff hobbylock 4842 serger
Pfaff has a video on threading the Hobbylock 4842 here: http://www.pfaff.com/mediafiles/threading_guide/index_en.html . You need Adobe Flash Player available on your browser. Enter the tutorial, the link is below the Quick Help paragraph. Then choose the correct machine (from the links across the top). Then use the drop-down menu to choose the stitch that you will be sewing for the appropriate threading video. Then click on the appropriate thread (below the video window) to see how to thread that section of the serger. (For two-thread stitches, you will see two options are greyed out.)
I hope this helps.
Jun 14, 2017 | PfaFF Sewing Machines
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Price of a hobbylock 4842
Difficult to say. Supposedly original new price was ~$700
Pfaff Serger Overlock Hobbylock 4842 Specifications
However, if it is a used machine, so much is subjective based on physical and operating condition, the accessories included, desirability of the model, where it is located, etc.
PFAFF HOBBYLOCK 4842 SERGER 2 3 4 THREAD OVERLOCK FREE SHIPPING NO RESERVE...
Jan 10, 2017 | Sewing Machines
Pfaff serger hobbylock 4870 converter stuck on on
Have you tried gently wigging the hand wheel while attempting the change?
Aug 30, 2012 | Sewing Machines
I need a manual for a Pffaf Hobbylock 4870.
http://servicemanualrepairs.com/book/pfaff-hobbylock-4870-instruction-manual/
Jan 11, 2012 | Sewing Machines
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
Hi :) Just got a Hobbylock 788 and need to thread
Here is the trick: If you look at your thread spools, left to right, thread machine beginning with thread from spool 3, then 4, then 1, then 2.
Thread 4 is tricky. You must line up the purple line on the big wheel on the right end in order to do this. Thread the machine according to the diagram on the inside, then, making sure you lined up the purple line, push the lever at the bottom of the machine (below threading guides) to the left while holding on to the thread end. This will push the thread up and along the horizontal arm you just threaded.
Mar 21, 2010 | PfaFF Sewing Machines
Manual
Sep 22, 2007 | Sewing Machines
Sewing Machines Logo
63 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
