Question about Dell Inspiron 6400 Notebook
Inspirion 6400 Mic Problams(win Vista)
My mic has stopped workin again !st time i had my motherboard replaced and had sound driver uninstalled and reinstalled then it worked.now its gone again works abit when wiggled in socket I uninstalled driver but now cant find it need help with driver and mic
  • erhaug Dec 14, 2007
    My mic is not working.
    Scholar:
  • 53 Answers
Try visiting the DELL web site and look for the software there as for the mic it may be loose inside the enclosure carefully open it and check for lose cables or screws
Posted on Aug 28, 2007
SOURCE:
I plugged in microphone but its showing it was not plugged in and my o.s is vista
Try to uninstall sound driver and reinstall sound driver again.
1. First solution : go to control panel, then system , device manager and select sound audio device , right click and uninstall the driver and restart the computer.
2. Soulution : check in system bios setup is there is any option available for mic enable or disable from there ?
3. update the sound driver.
4. check mic is working in another computer
Dec 29, 2010 | ASUS M2N-E SLi Motherboard
Sound from one speaker with mic plugged in.
Hi I am Vortash it sounds to me that this is linked to the realtek program off shutting off the speakers when the earphones are attatched , it is confusing the Mic plug on one channel as a speaker plug .. check in the advanced section of your mixer settings that you have not got the box ticked that says treat all inputs the same .. and the other that says mute rear when front plugged in ? as does mine .. ( same system that was my problem yours may be diffrent ) if this fails uninstall your realtek drivers and uncheck the realtek devices in device manager unistall them and rebboot the computer installing new drivers .. hope this helps regards Vortash
Jul 21, 2009 | Philips HP-170 Headphones
My mic of del ins 6400 using win vista not working it seem uninstall how do i make it work again
go to...audio properties - volume tab - advance tab - option tab (upside) - select properties - check box for mic volume.
May 30, 2009 | Computers & Internet
Dell studio 1535 loptop mic dosnt work
I have a Dell Studio 1737. I have install IDT 92HD73C1 v6.10 2009-02-17, Dell packed R204591.exe.
In the Control panel Sound, tab Voice, Mic device click button "Volumen" (spanish version) and select Internal Mic insted of Mic.
Thanks,
Juanma
Dec 01, 2008 | Dell Inspiron 6400 Notebook
Miccrophone
go to control panel...chose sound ..sound max panel..and make sure ur mic is on..(on default is off) u have to turn it on..just click red dots ..and if its green ur mic is already workin..:)...
Oct 01, 2008 | ASUS P5VD2-MX SE Motherboard
Microphone(MIC)Of head set not working(got removed wrongly)
This usually just gets reinstalled whenever you restart your computer be it Vista or XP. In your case, the drivers for the Microphone probably got deleted. The Microphone driver comes in the package together with the sound card. You'll have to re-install the whole sound card driver to have it start working again. You can do this from the Device Manager. After doing this, the microphone together with the whole sound card drivers should start working again.
Sep 17, 2008 | ASUS M2N-E SLi Motherboard
Sound device
reformat & repair your OS & setup
Apr 14, 2008 | Microsoft Windows Vista Ultimate Edition
Factory installed microphone isn't working anymoe
open up your volume toolbar, advanced and make sure that your mic is not muted, turned down or that your mic +20 boost is turned off. You can always uninstall sound drivers and have vista find them again on boot up, but Vista is such a new platform that your mic hardware may not be compatible. Good luck, I have never had good results with the windows mic.
Jan 24, 2008 | Acer Aspire 3680 Laptop
My mic has stopped workin again !st time i had my motherboard replaced and had sound driver uninstalled and reinstalled then it worked.now its gone again works abit when wiggled in socket I uninstalled...
If it works when you wiggle it in the socket, it's not a driver issue. It's either a problem on the motherboard again, or a short in your microphone cable. As replacing a microphone is a lot easier than replacing the motherboard again, I'd suggest finding another microphone, plugging it in and seeing if that fixes it. If it doesn't, I'm afraid it's the motherboard.
Aug 27, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
197 people viewed this question
Ekse
Clive
Clive
