Coleman 7333C881 A/C
My roof top 7300 series shuts down after running for about a half hour on really hot days. The unit will run fine all night long. Turned all the way up I'm getting 52 degrees at the duct on high blower. How cold should the air temperature be? Run on low cool it will trip the breaker after about twenty minuets too. I normally have it set between half and three quarters on high blower. Am I looking at the blower motor as the possible cause or a capacitor?
Ice maker
  • 8 Answers
SOURCE: Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Posted on Mar 30, 2008
SOURCE: 579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Posted on Sep 16, 2008
  • 121 Answers
SOURCE: coleman rv a/c
It is definitely with the compressor. It should more like you may have a weak winding in the compressor, you can a hard start capacitor (sp5 ) that will help the compressor on restart. Note that this is a last chance solution for a compressor.
Posted on Oct 01, 2008
dnewcombe1
  • 1564 Answers
SOURCE: 1996 Coleman Model 7333C8876. Have 2 units on
Check to make sure the drain tube is clear. It sounds like the blower fan is dragging in water buil-up.
Posted on Jul 24, 2009
projdoc
  • 2237 Answers
SOURCE: Air conditioner trips circuit only in the evening?
first off, it's illegal to release freon into the atmosphere. the epa could charge you $32,500, so keep it under your hat. second, if it's getting too cold where the evaporator coils are icing up, it's too lille freon, not too much. as for the breaker tripping, your compressor might be wearing out. if it's pulling too much current, the motor is failing and the compressor needs replacing. and do not do it yourself unless you're certified by the epa to move freon and have the proper equipment to recollect the used freon.
Posted on Jul 29, 2009
Hi, the roof top air conditioner drain keeps dripping on the door of the camper. is there any way we can adjust a hose or something to redirect the drainage? the camper is Coleman Pop up and the air...
Re: re-directing the water dripping over door ! Stop at RV parts store and get yourself a tube of "Dicor" self leveling sealant. It's recommended for rubber roofs, but works well on most roof surfaces.
Then I simply run a 3/8" bead of "Dicor" across wherever the run-off from AC is coming down, and re-direct it so the run-off comes off roof elsewhere. Don't try to smooth it out or anything, as I said, it is self leveling, just use a caulking gun, lay a bead about 3/8" and allow it to set for a few hours if you can. Make sure you pick a time where AC is off for a couple hours so (run-off) water isn't present. You"ll see the path (stain) on roof where it travels to guide you for redirecting. It's a simple fix, and no screws or nails required. Use the rest of the Dicor to fill in any gaps, cracks etc you see on sealant on the roof while your up there, but clean those before applying. If you can wipe your intended path down with some mild cleaner prior to applying bead, it will help it stick better as well. Even a little dish soap in water will do, just be careful, it gets pretty slippery when soap on there. Quick rinse with water then dry with rag, or let the sun dry it. Actually on a rubber roof, It should be scrubbed with mild detergent at least once a season anyway.
Feb 28, 2011 | Dometic Rooftop RV Air Conditioner
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it...
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Nov 14, 2010 | Dometic Rooftop RV Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Coleman 1300, condensation buildup inside unit, ceiling wet
Check for plugged drains under cover on roof, sticking out at base of unit usually. It should be running off roof.
Aug 04, 2009 | Heating & Cooling
Only at night the unit runs fine day-time it short cycles and will shut completely down and restart not just compressor the whole thing
Has anyone cleaned coils inside, as well as taken cover of on roof & done the same? If you remove inside filter etc, and look way up in front with a flashlight, you'll see coils that need cleaning usually. I use a shop vac with brush & long extension. Tight fit near top, but can be done, without damaging coils. Then take cover off on roof unit (with breaker shut off ) & clean both sides of rear fins, as well.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
Furnace not cycling properly.
you might want to check the filter, if the filter is restricting the airflow the furnace will over heat and it will shut down. if you turn it off and on it will reset it and it will try again. Pull the filter out half way and try that, if it runs fine then clean the filter or get a less restrictive one.
Feb 06, 2009 | Coleman Propane Forced Air Heater...
Coleman rooftop unit ac only.
These units should run in higher ambient conditions within limits. If your unit shuts down with an ambient temperature of 95°F there is a possibility that the system may have a slight over charge of refrigerant in the system or a slight undercharge. This can be easily checked under running conditions by checking the superheat of the gases returning to the compressor. You may also want to check the current draw and the voltage supply during these conditions that are causing the system shut down.
Sep 22, 2008 | Coleman Mach 15 Air Conditioner
7300 Series AC
***I guess nobody knows the answer. Ok. I'll search elsewhere.
Jun 14, 2008 | Heating & Cooling
Mar 30, 2008 | Heating & Cooling
Heating & Cooling Logo
110 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
