Question about Samsung Digimax S630 Digital Camera
Samsung s630 "file error"
I took a TON of photos on a memory card and was periodically able to check them, now I get a "file error" message as tho there are no photos and when I put it in the computer it says the disc needs to be formatted...what is the deal???
  • gaznsuzie May 31, 2008
    i was given a samsung s630 for christmas and have taken quiet a few pictures but then i try to download to my computer it is saying to insert file. and when trying to look at the pictures on the camera it says file error.
    President:
  • 1,114 Answers
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off)and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems. If you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link: http://www.cgsecurity.org/wiki/PhotoRec If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many. One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below: http://www.lc-tech.com/software/rescuepr... You can try the demo to see what you can recover before buying. Remember - Do NOT try & write anything back to the card until you can recovered your pictures to your PC safely! Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 28, 2007
SOURCE:
File error
new memory card probably needed.... unless your already missing one.... Just take it in to some electronics store and get there opinion.
May 28, 2014 | Samsung Digimax S630 Digital Camera
Losing photos
They are probably still there. Get yourself a card reader and use it to download your pics. f1eb652.jpg
Jul 06, 2010 | Samsung S630 Digital Camera
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
File error
I think you memory card slot in the trouble, if you have try to use another memory card and the result is the same. You can try to clean up your memory card slot.
Jul 24, 2009 | Samsung Digimax S630 Digital Camera
Whenever i take a picture and press to review it says file error
Hello!!
Try formatting ur memory card once and reload it ...
Apr 20, 2009 | Samsung Digimax S630 Digital Camera
File errors, distorted photos.. I hate the Samsung L100!!
regarding the use, you have to check if you are using the right memory card for your camera.
you can only use 2GB sd card or 4gb sdhc card.
try this and if you still have an error message. you better send the camera for service.
Jan 19, 2009 | Samsung L100 Digital Camera
'File error' message on samsung L200 camera when viewing a photo
Possible solution:
I had/have the same problem using L200 and SDHC memory card, called Samsung. Can't view certain pictures on camera or computer, camera freezes when viewing those certain pictures, green light flashing.
Samsung support told me that I needed to copy my (good) pictures to a computer first because a memory format will erase everything. Then format (menu->settings->format->yes) my memory card. Tried this just now and took some new pictures, so far so good.
Jan 15, 2009 | Samsung L200 Digital Camera
Recover erased data
Ok,
Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Nov 02, 2008 | Sony ICD-B10 Handheld Digital Voice...
Memory card error - E50
Try formatting the memory card via a card reader connected to your PC. Use FAT32.
May 24, 2008 | Canon PowerShot A75 Digital Camera
Memory Card
If you transfer the photos to your computer from the camera, you should be able to save to another memory card. I can't say whether or not the photos on the new memory card will show up on your camera since there may be certain requirements to display on camera screen.
Plug your camera into the computer USB or insert old memory card. A box should pop up giving you the option to view files. Copy and Paste (or Drag) selected photos to a specified folder on your computer (Like My Pictures in My Documents). Insert new memory card. Copy and Paste (or Drag) selected photos to the drive for your memory card.
May 06, 2008 | Samsung Digimax S630 Digital Camera
Samsung Digimax S630 Digital Camera Logo
244 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
