Question about Stanley Lawn and Garden Deluxe Poly 2Gallon Sprayer 72020
Will pump up but wont spray stanley lawn sprayer 72020
3 Suggested Answers
  • 438 Answers
SOURCE: Stanley 61804N Professional Backpack Poly
Doc,
Yes, please replace the seal.
Posted on Mar 05, 2011
  • 3 Answers
SOURCE: I have a Stanley Lawn
Check for any missing washers or seals or check to see if they're not broken.
Posted on May 16, 2011
Parts sprayer stanley
I would like the answer yo that question
May 10, 2013 | Stanley Professional Backpack Poly...
My 2 gal yellow ortho lawn sprayer will not get pressure to spray when I pump it. What can I do to resolve the issue?
First Check the gasket around the lid, and the one around the pump housing for any kind of leaks. If this does not solve the the problem, check the sprayer to be sure it is not on all the time you are pumping.
After that you may need to invest in a new sprayer.
May 08, 2011 | Garden
I have a Stanly backpack sprayer pro 61804n and need a repair manual. Were could I find one. Thank You, Chuck
The picture looks a lot like a Solo sprayer I have. I wouldn't be surprised if Solo made them for Stanley. Do a search for Solo sprayers. They have a site. My sprayer is a Solo 425
Jun 21, 2010 | Stanley Professional Backpack Poly...
MY STANLEY 61804 DOES NOT PUMP. THE PUMP HANDLE JUST POPS STRAIGHT DOWN EVERY TIME i TRY TO PUMP IT. ONLY USED 3 X. wHATS THE PROBLEM ???
the darker Seal has come off the plunger at the bottom of the unit , easy 5 min fix , just unscrew the allen keys at the bootonm take off the cover and remove the plunger , you'll see the plunger seal still inside you can fish it out with an allen key or similar tool clip it on again and reassemble
Oct 29, 2009 | Stanley Professional Backpack Poly...
The spray unit bent and broke...
Lowes or Home depot sells replacement sprayers. Hose to tip all included.
Aug 18, 2009 | Stanley Professional Backpack Poly...
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Stanley Lawn and Garden Deluxe Poly 2Gallon Sprayer 72020 Logo
21 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Stanley Garden Expert? Answer questions, earn points and help others
