Does p3 sound cards support in p4 machines - Computers & Internet
  • 40 Answers
Probably it will not support.But you can downlaod drivers for your p4 from below link:
http://members.driverguide.com
Enter your motherboard model number and search and download from results.
Regards,
Rahul
Posted on Jul 15, 2013
I have nothing to plug p3 and p4 into when all on no signal
Sometimes if a VGA cable is not screwed into to both your Tower and your Monitor, it can get loose and thus resulting in no signal.
Another cause of a Monitor Displaying the no signal message would be due to the Graphic Card failing, or possibly due to the Graphic Card not correctly being seated.
Other Thoughts
Usually P3 and P4 refers to a cable on your power supply that needs to be attach to your motherboard to supply extra power.
Note:
If your P4 cable is not plugged in before turning on your computer, this will also result in your Monitor displaying the no signal message.
Keep in mind though, if your computer has not been opened or is not a custom built PC, you should not have to worry about such issues as your P4 cable should in theory be connected. However I guess safely checking won't hurt anyone.
Mar 30, 2015 | Computers & Internet
Tip
How to use a P3 power supply with a P4 or newer motherboard.
Well its fairly simple, You need the following cable to convert your P3 power supply into P4 power supply.
The pictures pretty much explain every thing, this is the only plug that is not present on a P3 power supply. You can make this cable your self by salvaging connectors from non-working power supplies and other computer peripherals. The connections are straight forward just connect both the yellow wires to the single yellow wire and the black wires to the black wires and your done.
on Feb 09, 2010 | Computers & Internet
DS Slot 1 part number
Slot 1 - P2 (DS CARD slot)
SLot 2 P1 (GBA CARD SLOT)
P3,P4 are the flex clip for up and down lcd screen
and others par number, i always check on www.logictoyz.com, some times,they have image there
Mar 19, 2009 | Nintendo DS Lite Console
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Sound card
hello sir,
board is energy p3 pls check ur soung card model, to check ur sound card model in run command type dxdiag.exe and check sound detail if u found ur sound card detail go to google page type ur model of sound card and download .
Thanks for calling to us have a nice day
Aug 02, 2008 | Computers & Internet
Changing a P3 motherboard for a P4 motherboard
P-4 boards want at least a 300w power supply, P3 were not so picky. Next, swapping boards is easy but remember to stay in the same form factor, (the relative size length and width) a server board won't fit in a micro case.
The location of the stand offs (where the screw holes are) may have to be changed. P4 boards have 20 pin or 24 pin power connectors so the appropriate power supply will need to be ordered. If you are running a lot of peripherals a 450w ps at least.
Now you decide if you want a board with on board, video,nic,sound,etc.
then you have to order the supported processor/heatsink and fan/thermal grease/supported Ram etc.
I've been doing this for years so i probably left out a lot.
Lately because of costs I've resorted to backward building.
I decided since DDR2 is cheap, find a board that supports that ram in a processor socket I want to use (socket 478-775) etc.
Mar 21, 2008 | Intel Motherboard
Intel p3 audio driver
hi kumar i need a sound driver for my p3
Feb 05, 2008 | Intel Steinberg Nuendo AudioLink PCI 96...
Dell Dimension 4100 Mobo upgrade to a P4 based system
Well the two would not be compatible cause one is a P3 and the next is a P4 two completely different socket types so it wouldn't work but what u can do is buy a new motherboard if u want to upgrade to a P4...thats the only thing that is recommended from such a devices cause an upgrade wouldn't be possible to do .
Nov 22, 2007 | Dell (2336V) Motherboard
Replacement
you should be able to use the same HDD, Floppy drive & CDrom drives, You should be able to use the case, if it has a removable plate for the outputs as they will most certainly differ from your original mobo. However you need to check your PSU as the P4 has a requirement for a 4pin 12 volt line which is not present on the older PSUs, however you can get a new PSU and fit it into your case for about £30-£40 Your P4 motherboard is also unlikely to use the same RAM as your P3 so that will need to be replaced. (as it will be incompatible with the new processor)
Oct 08, 2007 | Intel 845GE Motherboard
Whirlpool Duet Dryer GEW9250P (electric)
Here is a list of possible causes. NONE OF THE LEDS LIGHT... Check to make sure that ribbon connectors P3 and P4 are inserted all the way into the machine control electronics board. (To access the machine control, pull the dryer away from the wall and remove the three screws from the top panel on the back. Slide the top panel rearward about 1/2" and lift. The machine control is on the left hand side. P3 and P4 are the "ribbon" connectors going into the board.) A PARTICULAR GROUP OF LEDS DOES NOT LIGHT... A group or combination of LEDs share a common electronic connection. If this connection is open, all of the LEDs in the group will be disabled. If this occurs, replace the entire console electronics and housing. ONE LED DOES NOT LIGHT... Press the button associated with the LED several times. If the LED does not light, the LED has failed. Replace the entire console electronics and housing. NO BEEP SOUNDS... If the associated LEDs do light up, the beeper circuit may have failed on the machine control electronics board. NO DRYER FUNCTION IS ACTIVATED WHEN A PARTICULAR PUSHBUTTON IS PRESSED... If the associated LEDs do light up, the machine control electronics board may have failed. AN E3 ERROR CODE IS DISPLAYED... An E3 error code means that there is a user interface or a software mismatch. It can also mean that a component on the console electronics,or the machine control electronics board has failed. Hope this little tutorial gets you where you need to go. Let us know how it turns out, will ya?
Sep 13, 2007 | Whirlpool GEW9250P Electric Dryer
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
