Question about SanDisk Sansa e250 MP3 Player
MY SANSA E250 JUST DOESNT START.......
I TRIED CHARGING IT FOR OVER A DAY,WHEN EVER I SWITCH IT ON I JUST GET THE BLUE JOG DIAL DISPLAY,THE SCREEN WEARS A COMPLETELY BLANK LOOK,I TRIED RESETTING IT BY HOLDING THE POWER SWITCH FOR OVER 20 SECS LIKE RECOMMENDED HERE,STILL DINT WORK,WHAT DO I DO???? PLZZ HELP..
  • sunsun Sep 01, 2007
    mike thnxs for the suggestion,how do i perfrm recovery mode & also upgrade the firmware of the player.... i do not have a display at all... apart frm the jog dial blue lit display ,nothing else seems to work.... i also tried chargig it for like 2-3 hrs.. just dnt work.
  • sunsun Sep 04, 2007
    Mike thnxs again.... i tried doin wht u said... but like i mentioned earlier... i just dont have a display on the screen.. i also downloaded the firmware update like u mentnd... but i just dont c anything on the screen.. will probably call the tech spprt dept.. thnxs mike.
    Scholar:
  • 155 Answers
Try holding the menu button until it turns off then leave it off for around 30 minutes then try to power it back up. If it still wont turn on perform recovery mode and upgrade the firmwar eof the player if havent done so.
Posted on Aug 29, 2007
  • Micheal Thompson
    Micheal Thompson Sep 03, 2007
    Here's how Enable the Hold switch then when it is enabled press the RECORD BUTTON and while pressing the RECORD BUTTON press the MENU BUTTON until it shows in the screen WELCOME TO RECOVERY MODE. Then before you connect the device to the computer. download the sansa firmware updater at the sandisk site. Then when it ask you to connect a device that is the time you will have to connect a device to the computer. If it still failed i suggest calling sandisk technical support.
I have sansa e250. when i switch it on only blue light glows all round the joystick. i could not switch on my sansa. i tried resetting by pressing menu key for more than 15secs, also i removed and...
i have sansa e250. when i switch it on only blue light glows all round the joystick. i could not switch on my sansa. i tried resetting by pressing menu key for more than 15secs, also i removed and re-installed the battery but it is not working. pls solve
Oct 21, 2010 | SanDisk Sansa e250 MP3 Player
My e250 will not turn off & will not turn on-Screen is gray w/vert. lines in it
You need to remove the battery and let the system power down completely. I have had this problem and the others I have seen on this site. Removing and reinstalling the battery solves many problems. Just letting the battery drain is not good for it and may take a really long time.
Sep 28, 2008 | SanDisk Sansa e250 MP3 Player
Format sansa E250
when i turn my mp3 "on" then it will refreshered and the screen will turn black it will not display anything what should i do, and it is not charging too.
Sep 23, 2008 | SanDisk Sansa e250 MP3 Player
My display doesnt work
My son had the same problem. I think he let it get too hot, left it setting in the sun too long. We tried everything. Unfortunately, he had to reformat, and lost everything. But he had all his date backed up on an external harddrive. Sorry....
Jun 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Take the screws out of the back, take the battery out then put it back in again. This worked for me.
May 02, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 blank screen problem
I would recommend that you tried to reset the device if you have not done so..To reset the device preses the power button for about 15-20 seconds..let me know what happens....
Hope this help
Thank You
Computerrep
Mar 20, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player display gone blank
I believe this is answered already. Turn the hold button on. Red light will be on. Hold the rewind button while you insert it into the computer. Please search online this has been answered. I am recalling from what I read a few minutes ago.
Feb 04, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 frozen white screen
hold the power button and forward button together for 2 minutes
Jan 02, 2008 | SanDisk Sansa e250 MP3 Player
Screen black
Try to get a firmware upgrade done..once you have that done you should be able to use the device without having any problems..
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa E250- Only the blue light comes on? HELP????????????
Try this: Switch your Sansa e250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the e250 LCD screen displays "Welcome to Recovery Mode" (if the LCD remains black, keep pressing long enough -- about 10 seconds -- then proceed to the next step) 5. Connect your e250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa e250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the e250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa e250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... or use this Sansa Firmware Updater link: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player (or find the most updated firmware) and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your e250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your e250 and 90-99% of the time, it would boot up successfully. I hope this helps.
Apr 20, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
